Normal vibes?
Old Aug 7, 2012 | 12:08 AM
xpilot's Avatar
xpilot
Default Normal vibes?
I have an 03 EGC, stage 1, pcv, and rinehart true duals. Whenever I get up to about 75 mph, there is so much vibration, that my feet and azz start to go numb. Got around 30k on it. Motor mounts? Bent crank? Bought from a stealer last year with 25k, and have done nothing to it but ride.
Thanks in advance
Old Aug 7, 2012 | 12:13 AM
z06elmo's Avatar
z06elmo
i assume it didn't vibe when you bought it with 25K miles on it?
Since the vibration has to do with bike speed vs. motor speed, makes me think it's something rotational at speed, like the wheels/rotors/sprocket something like that, not related to the engine.
Old Aug 7, 2012 | 12:17 AM
mkguitar's Avatar
mkguitar
there are a million things to check.
since the mufflers have been changed, check that they are not binding on the mounts under the saddlebags, and are not contacting the frame anywhere.
motor mounts should be checked as well.
try to determine if the vibes are speed related ( chassis, wheel balance, etc.) or rpm related...75 mph on your bike is about 3200 rpms in 5th gear...do you get similar vibes in 3rd gear at 50 mph, which is about 3300 rpms.
that would point at a motor problem or mount
mike
Old Aug 7, 2012 | 12:25 AM
xpilot's Avatar
xpilot
Definitely related to speed. I don't get the vibration at similar rpm in lower gears. High frequency, so I figured engine related.
Old Aug 7, 2012 | 06:16 AM
RK Joy's Avatar
RK Joy
Maybe threw a wheel weight if it is related to speed and not RPM?
Old Aug 7, 2012 | 06:25 AM
Toe Knee's Avatar
Toe Knee
Cam chain tentioners. Should be looked at with 30k anyway.
Old Aug 7, 2012 | 09:26 AM
xpilot's Avatar
xpilot
Forgot to mention that it has the SE cam chain tensioner
Foodog
Sep 4, 2014 04:55 PM
rider123450
General Topics/Tech Tips
Oct 10, 2011 07:56 AM
Harley kevbro
Exhaust System Topics
Dec 26, 2007 08:36 PM
Dalej
Aug 14, 2007 05:42 PM
exhdo1
Sep 13, 2005 05:30 PM
