1st 96 Ultra If there is anyway you can let me know if theres anywhere to pick those up without having to order or if not then the best place to order! giacomo56 and fwb35 if you could as well I would appreciate it
You can get Mobil 1 v-twin at Autozone or Wal-mart. Look up Amsoil Distributors in your area http://www.amsoil.com/locator/dealerlocator.aspx for Amsoil Severe Gear lube for the tranny. Lots of independent shops stock it. You can also get 20/50 Amsoil from the distributor as well. Don't have a Distributor in your area? You can become one here for a small fee. http://www.amsoil.com/opportunity.aspx
yea what they said , good luck , ride safe and have fun , Advance Auto is were I get my Mobil 1
100% what this guy said. My '99 runs great with this combination. And yes there will be ticking and engine noises after this...its a Harley!
I disagree. When my 96 was stock it made no top end noise with amsoil,royal purple or motul. Even conventional pennzoil 20w-50 was quiet. I put the great mobil 1 in my engine and the top end sounded like a can of marbles bouncing around. So to me that isn't normal.
Now I've got new cams,heads etc and decided to try the almighty mobil 1 again and again the top end sounded like it was getting pounded. So I drained it out and used royal purple and wow,quiet top end. This time I used motul and again the top end is quiet so I will never waste another nickel on mobil 1. Not when there are other products for the same price that work better,in my bike anyways.
