Kury USB charger
Old Aug 14, 2012 | 01:36 PM
sgdiesel's Avatar
sgdiesel
Default Kury USB charger
Hoping someone can help out with this. I am in the US in a couple of weeks time and was keen to lay my hands on the Kury USB charger, as per this link
http://www.kuryakyn.com/products/4206/usb-power-source
Problem is, everyone seems to have stocked out and, although I order 2 a couple of months ago it looks like they will not be available.
Are there any decent alternatives. In particular, I am interested to hear about the devices which are proven for charging iPhones.
Thanks
Old Aug 14, 2012 | 01:53 PM
mkguitar's Avatar
mkguitar
hmmm,, my usb charger ( in the tour pak) cost $8 at autozone ( auto parts chain store)..similar at walmart ( asda).
it charges my ipod/iphone/camera etc.
I also have a small 12 v usb plug which cost about $7. I used to plug that into the cigar lighter before I installed the isimple 30 pin iphone plug
so 3 alternatives, under $30 for all 3
http://www.autozone.com/autozone/acc...er=210400_0_0_
Mike
Old Aug 14, 2012 | 02:00 PM
sgdiesel's Avatar
sgdiesel
Mike
Should have given more info Mike, this is for a scoot that does not have any 12V lighter connections in place so need a complete device that connects to a switched live supply.
Prefer to go direct to USB rather than building a Christmas tree of plugs and adaptors
Thanks
Old Aug 14, 2012 | 02:03 PM
Manninagh's Avatar
Manninagh
Griffin PowerJolt SE Car Charger for iPhone and iPod, 1 Amp. Available on amazon.co.uk right now for Ł9.79, mate.
1 amp is quick carge for iPhone, and it's a short charger so doesn't hit tank when used in cigar socket on fairing. Curly wire doesn't get in the way either. Also long enough for use in pannier if you've got an auxiliary socket rigged.
I use my iPhone for sat nav and tunes, and I've used this for a year without dramas. If you want a generic USB type charger, just make sure the output is at least 0.75 amp if you want to charge iPhone or iPad.
Old Aug 14, 2012 | 02:07 PM
mkguitar's Avatar
mkguitar
your SG doesn't have a lighter socket? ( next you are gonna tell me it doesn't run on diesel)
this is similar t what i have in the tour pak, although mine is 2 x usb, 2 x 12 vdc
http://www.walmart.com/ip/Pyle-PL12V...arger/17242492
cut the plug off and wired it to the "run" light circuit. my stuff in the T/P charges as I run down the road- and as noted above I use the isimple to charge and get audio to my stereo- and my ipod touch is mounted where I can see and use the display
mike
Old Aug 14, 2012 | 02:14 PM
sgdiesel's Avatar
sgdiesel
mike
My normal bike is a Ultra Limited, but I have bought a VTX in the US for touring around for a couple of weeks each year. I am well sorted with the Limited, easy when you have the 12v output in place already
Old Aug 14, 2012 | 02:16 PM
sgdiesel's Avatar
sgdiesel
mike
This is best explained over a pint, I am in your neck of the woods end of August, kicking off in Tucson and heading over to Atlanta - taking a couple of weeks
Old Aug 14, 2012 | 02:35 PM
Casper's Avatar
Casper
You can go to about any auto parts store and get most of what you'll need to power up any accessory....or contact this company
http://www.powerlet.com/products
They have about anything and their stuff is top of the line...
Old Aug 14, 2012 | 02:59 PM
sgdiesel's Avatar
sgdiesel
mike
Looks like really well made kit, thanks. I will contact tem to see if they have a USB option
Sturgis67
Apr 21, 2022 05:35 PM
dloreski
2014-2024 Touring Models
15
Apr 27, 2016 09:33 AM
surfnorthwest
23
Jul 18, 2014 07:26 PM
asm481
Jun 23, 2014 05:54 PM
troy.j
Dec 1, 2009 12:34 PM
