Questions on Nav Interface Module Install
Old Aug 15, 2012 | 09:55 AM
StevenRK's Avatar
StevenRK
Default Questions on Nav Interface Module Install
I'm planning on installing this on my 2012 Ultra Limited this weekend for my 665. It looks pretty straight forward. I've read thru the many threads in this matter...and still have a couple questions...
1 - The only part I'm not sure of is removing the seal pins on the 25 pin connector on back of radio. The istructions references the service manual addendum for removal instructions, but doesn't specify which one (addendum) to use. Is removing these seal pins difficult? Can I just use the jewelers screwdriver as mentioned in threads? (LOTS of confilicting info)
2 - Has all the issues been resolved with the updated NIM Kit that now ends with an "A"?.
3 - Any other hints for install?
3 - Any reasons outside of spending $150...why I shouldn't do this?
Thanks
Steve
Old Aug 15, 2012 | 10:25 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
The seal pins are just plastic hole plugs..... easy
Issues have been resolved with the A part number
You have the Ultra harness, so installation is easy......
Street glides and Road Glide Customs require a connector kit, and the instructions must have been written by a crack addicted 5 year old kid.
Old Aug 15, 2012 | 01:05 PM
Airborne350G's Avatar
Airborne350G
It is pretty straight forward as you say as long as you know how to unlock the 26 pin connector. You do not want to take it completely apart. It is a pain to get all 26 pins lined up again.
Old Aug 15, 2012 | 01:21 PM
StevenRK's Avatar
StevenRK
1- Unlock the 25 Pin Connector? Whats the trick? It doesn't just unplug???
2- To use the spare power connector in headlamp...do I need to take headlight apart to get to wiring?
Steve
Old Aug 15, 2012 | 01:36 PM
shooter5074
Steve
If you have the service manual, the way to unlock the connector is in the back someplace with the other connectors. You need to slide the connector slightly open to be able to insert the pins. There are locks on the sides of the connector to open it up.
Why do you need to use the spare power connector in the headlamp?
http://www.harley-davidson.com/en_US...ts/-J05169.pdf
Here's an excellent article on the iPod interface that uses the same connector, and how to insert the pins for reference.
https://www.hdforums.com/forum/touri...-2011-rgc.html
Old Aug 15, 2012 | 02:04 PM
StevenRK's Avatar
StevenRK
I temporarily have Zumo 665 wired to cig lighter. I figured if I opened up fairing I might as well connect power correctly. I was avoiding running new power under tank. Other suggestions. Great article on 25 Pin connector BTW.
Old Aug 15, 2012 | 02:08 PM
shooter5074
Do your power to the cig lighter wires. It's switched and works great for a GPS.
Old Aug 15, 2012 | 02:46 PM
prostar's Avatar
prostar
Consider mounting the XM antenna on top of your front master cylinder with velcro. You will get better reception.
Old Aug 15, 2012 | 02:50 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Steve
#2 - no. there are spare + / - connectors off the wires running to the headlight - they just sort of hang there. The RT 660/665 mount instructions says to use the spare headlight connectors but the cig lighter should be fine too.
ant46
Sep 17, 2017 08:05 PM
sicpup
Oct 28, 2014 09:33 PM
rob0225
Audio Systems
Mar 27, 2013 11:41 PM
Shark Ride
Aug 26, 2011 08:56 AM
Da Butcher
Jul 22, 2009 11:03 PM
