Hayden m6 tensioner installed
Old Aug 27, 2013 | 02:23 AM
  #61
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Originally Posted by TUCCI
I've been studying the oem auto tensioner all weekend and I've got an idea for a prototype to make it an adjustable ...
If you remove the spring, can you thread the guide pin or slide a threaded tube over it to secure all parts?
I'm thinking of the threaded tube used to hold and power a light bulb
Old Aug 27, 2013 | 09:50 AM
  #62
0ldhippie's Avatar
0ldhippie
Just installed one on my '09. Ran them on a couple other bikes with good results. The stock shoe had little wear @ 35k but the chain did seem tight? Install pretty straight forward. Ended up with 5/16 without shims. Figure the shoe will wear to the rollers and be right at 3/8. Chain doesn't seem as tight as stock. Hoping it will save primary bearing...
Old Oct 7, 2013 | 07:55 AM
  #63
Clayvis's Avatar
Clayvis
Just installed one on my 07 Fatboy. Got the exact same results...5/16 with no shims. Chain was tight, but did have some play. Using a zip tie made installation easier. Compressed the springs with both hands and used my teeth to pull the zip tie tight! Where's a friend when you need one! So far happy with performance... seems to be working well.
Derik
Feb 3, 2017 03:10 PM
RetDetSergeant
Jul 25, 2015 09:56 AM
propflux01
Jun 18, 2015 07:45 PM
sbeamer
Nov 15, 2014 04:53 PM
PhatAnthony
Vendor For Sale Classifieds
27
Mar 14, 2013 06:13 PM
