Pretty much all speedos are off on the "high side", saying you are going faster than you are. In order to be perfectly accurate would incur more cost, so they allow them to "err". The key is, thay have to "err" on the "high side", there is actually some government regulation about that. They are not allowed to say you are going slower than you really are. I know of no tolerance range mandated and have seen some pretty far off. Radar guns have a tolerance error also which is why most times you are allowed 10 over the speed limit, that allows for calibration errors with the gun and the speedo. That's my story and I'm sticking to it.
The crappy thing about it is that you end up showing more miles on the speedo than you actually have driven. You're riding at 75 MPH's but your speedo says you're doing 80 MPH's. Granted that only off 5 miles after an hour of ridding, but that 5 miles really adds up after a couple of years............
But you guys are talking 3-5%. At 70mph on my speedo...Im actually going 62 on GPS. Mileage is consistant......on a 100 mi trip, I log 111. Seems like alot to me.
The 3 HDs I've owned have all been about 3% off. Assuming that the accuracy of your GPS is correct I'd suggest your bikes gearing has been changed or you have a much smaller than stock rear tire.
I thought that might be the case too with them being that far out, BUT I used the GPS out of the truck, and then ran them again with the GPS out of the car. Same results.
Rice sucks! I think they set them that way so you think you are getting GREAT gas mileage!
[QUOTE=frog13;10266095]HEY! Maybe your GPS is wrong!
/QUOTE]
Think about that.......... If a GPS is wrong, it doesn't work! If it doesn't know how fast you're traveling it doesn't know where you are. If it doesn't know where you are you miss your turn. It doesn't work.............
We covered this in here recently. Most manufacturers work on speedo accuracy of 0 + 5% and in some countries it is legally mandated. Your choice of tyre brand will have a small affect on speedo accuracy, as will worn tyres compared with new ones. So your speedo is never going to be as accurate as an external device like gps.
You guys remind me of Sheldon on the show "Big Bang Theory", I guess we need to put <sarcasm> or <humor> after our comments .......ummmm, I know how GPS works.
