Sta-bil vs Seafoam
Old Aug 31, 2012 | 06:56 AM
Stew Pidaso's Avatar
Stew Pidaso
Default Sta-bil vs Seafoam
I used to use Sta-bil brand fuel stabilizer when storing my bikes. But, I noticed that for the first one or two tanks of gas mileage suffered resulting in 20-30 miles less in range on a tank full. I have swiched to Seafoam brand and have noticed no drop in MPG's. Has anyone else experienced this?
Old Aug 31, 2012 | 06:59 AM
1sweetglide08's Avatar
1sweetglide08
Just brought a bottle of Seafoam this year. Haven't tried it yet, but wanting to try it in my oil and fuel. Will be following this post.
Old Aug 31, 2012 | 08:28 AM
fishbust's Avatar
fishbust
The seafoam will break up carbon but you need the stabil for long term storage of fuel.
And if you are stuck using ethanol in your gas, for storage it wouldn't hurt to add a splash of startron to your fuel.
Old Aug 31, 2012 | 09:09 AM
Weavr99FLHT's Avatar
Weavr99FLHT
Yes, mpg sucks first tank. Before first ride in the spring, I syphon 4 gallons out into the can for the lawn mower, then go fill it with fresher gas. I use sta-bil
Old Aug 31, 2012 | 09:36 AM
DDuess's Avatar
DDuess
Same here, mpg is less for that tank, but I have switched to marine Stabil (blue), it is labeled for use with ethanol treated fuels, and have had good results, ie no carb gumming or corrosion in bike, boat or power equipment fuel systems.
Old Aug 31, 2012 | 10:38 AM
jjnoble's Avatar
jjnoble
I've noticed that too, that and the bike runs a little rough. Seafoam doesn't do that.
Old Aug 31, 2012 | 10:48 AM
z06elmo's Avatar
z06elmo
seafoam is a greater cleaner tool. used to clean your carbon build up, injectors, can clean up the crankcase as well as other items. It's not used in the same manner stabil is which is to stabilize the fuel during longer term storage. Seafoam would help in this regard, but not nearly as much.
Old Aug 31, 2012 | 11:01 AM
Python357's Avatar
Python357
I use seafoam in my boats during winter storage, especially in the fuel injected engines - just don't have a clue what impact it has on gas mileage
Old Aug 31, 2012 | 02:47 PM
Stash905's Avatar
Stash905
I have always used SeaFoam for winter storage and have never had a problem.
Old Aug 31, 2012 | 02:48 PM
mgmmgm's Avatar
mgmmgm
Thumbs up Marine grade
+1 on the marine grade stabil for your storage / non ride time over the winter.
It does the trick to make ethanol fuel not separate.
Used it last year in the Roadking, good to go.
Use it in my gas for law mower year round and from that can to mix 2 cycle oil for my Stihl products.
