Run/Brake Turn Siignal Module
Old Sep 3, 2012 | 05:33 PM
DannyZ71's Avatar
DannyZ71
Originally Posted by Stiggy
Orange is Accessory, so just cut the orange wire?
If you do that, then your 4 way flashers may not work if ever broken down at the side of the road. You would want to switch to accessory to do that otherwise you'd have to add a dead battery to the list of parts to fix whatever else needs it. But, to some, having the flashers work is a minor thing.
Old Sep 3, 2012 | 05:50 PM
Stiggy's Avatar
Stiggy
Where and when I ride, the flashers are huge to me. Lose your headlights and the flashers give you enough light to pull over safely. ( Two times now.)
I suppose an easily accessible switch vs having to pull the seat every time would be the ticket.
Old Sep 3, 2012 | 06:37 PM
dawg's Avatar
dawg
Just use a 12v tester and check the pinout and swap around the two wires accordingly.
Old Sep 3, 2012 | 07:41 PM
FL-kruzen's Avatar
FL-kruzen
I have the same issue with mine. Dawg, what do you mean about switch out the wires?
Old Sep 4, 2012 | 06:18 AM
psychocircus's Avatar
psychocircus
Originally Posted by psychocircus
I wanna know which wires to swap also. Hated that they stay on in acc position.
Never saw it...ill look into it. Thanks dawg.
Think ill lose 4ways doing it this way from the sounds of it?.?
Old Sep 4, 2012 | 06:38 AM
Notgrownup's Avatar
Notgrownup
I'd like to know which two wires to swap so I could listen to the radio as I clean/service the bike each weekend.
I don't have electric service out to the area where I typically work on it so I've currently been pulling the seat and disconnecting the module if I'm going to be out there for any length of time.
And I only forgot to plug it back in once, (errr maybe twice.)!
C'mom Stiggy we're in NC ...not BFE...Go to Walmart and buy you a little battery radio...Making us look bad here...LOL...
Attached Thumbnails Run/Brake Turn Siignal Module-boombo.jpg
Old Sep 4, 2012 | 07:16 AM
nvsteve's Avatar
nvsteve
That's funny!
Old Sep 4, 2012 | 07:24 AM
frenchbiker's Avatar
frenchbiker
I installed this module as soon as I got my Ultra but I modified it a few weeks later, after I followed my bike on a friend's bike and noticed that the brake lights weren't as visible as I expected. The single filament bulbs in the turn signals don't get much brighter when I brake.
After the modification, the turn signals are no longer running lights, they only turn on when I brake or when I turn which, in my opinion is much safer.
By the way, I have running lights in my TourPak so a total of 3 running lights in the back is enough IMO.
Old Sep 4, 2012 | 05:36 PM
Stiggy's Avatar
Stiggy
Well yeah, there's that...
Old Sep 4, 2012 | 06:26 PM
kj68's Avatar
kj68
Default Turn signal module
Frenchbiker, can you elaborate on the mods you did. I would like to do the same to mine. I've always thought it looks like the brakes are always on.
Thanks, kj
