2011 Street Glide OEM mufflers
Old Sep 3, 2012 | 06:55 PM
lowrider1499's Avatar
lowrider1499
Default 2011 Street Glide OEM mufflers
Can these stock mufflers be drilled out to improve the sound like I did on my old Dyna? I haven't read where anyone has done this. Would it require a re-tune?
Thanks,
Mike
Old Sep 3, 2012 | 07:22 PM
pontiac69's Avatar
pontiac69
I have read a bunch of threads about people using a 1 3/4" hole saw on the exit side of the muffler. THis allow you to remove the baffle.
https://www.hdforums.com/forum/8618095-post16.html
Old Sep 3, 2012 | 07:28 PM
mkguitar's Avatar
mkguitar
you will likely get a better result removing the cat from the header pipe- some riders report that the stock mufflers work well once the restriction the cat causes is removed.
as for drilling mufflers, in most cases this is attempted on the way to buying a performance muffler that works well all through teh rpm range.
drilling often removes all the "science" from the design of the pipe and may reduce performance.
the best one is the guy who tries drilling with the mufflers in place and screws up his headers with all the force he applies to the mufflers...and of course it is possible for metal fragments to be sucked back into the motor from the exhaust.
mike
Mike
Old Sep 3, 2012 | 07:45 PM
FL-kruzen's Avatar
FL-kruzen
Get you a set of these, not costly and sound real good.
http://www.ebay.com/itm/Exhaust-Slip...r#ht_867wt_685
Old Sep 3, 2012 | 11:33 PM
Rickl's Avatar
Rickl
Having installes Jackpot duals with OEM mufflers I can say that the exhaust sound did change for the better. It still wasn't where I wanted it so I found some Jackpot 3.5's and love it now. Changing out the cat header is a must, with the upside being you eliminate a lot of heat.
Old Sep 4, 2012 | 04:34 AM
VTL nut's Avatar
VTL nut
Thanks,
Mike
I initially removed the baffles from my 2012, with about a 1 1/4" hole.
My cat is still in tact, and it made a nice difference.
Before a couple hundred mile jaunt last weekend, I took my torches and opened up completely. Sounds better yet. I stayed away from the welded seam by about 3/8" so I have about a 2 1/2" opening. You can see into the muffler quite a ways when you are behind the bike, but she has a nice bark when on it and a descent rumble at idle. This all with the cat still in place.
And No, no retune necessary (allthough I had the PV from my last bike which I reliscensed to this one).
Old Sep 4, 2012 | 06:50 AM
geezer glide 56's Avatar
geezer glide 56
mike
Mike
I don't guess that I am familiar with anything being sucked up the exhaust system....Unless the engine is running backwards or has serious valve issues.
Old Sep 4, 2012 | 09:05 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Fits Street Glide, but doesn't fit a Road Glide? WTF
Old Sep 4, 2012 | 10:17 AM
mgmmgm's Avatar
mgmmgm
Drago's bike works dual exhaust, or Fuelmoto stuff.
Old Sep 4, 2012 | 06:26 PM
lowrider1499
Thanks for the input.
Much appreciated.
Mike
U-234
Exhaust System Topics
Jan 18, 2016 07:59 AM
John Bakker
May 6, 2012 04:48 PM
crackercap
Sep 30, 2011 11:14 AM
dankFLSTF
Jul 16, 2011 08:32 PM
tomtek
Oct 11, 2010 04:17 PM
