Power duals question
Old Sep 10, 2012 | 01:31 PM
Grillfish's Avatar
Grillfish
Originally Posted by glcash
Just talked to VH Tech support. The old version for 2010 has 02 ports that stick out more. the newer version has the flatter 02 ports. Both head pipes have the sensors in the same location. I will go with the old version since they are in stock. New version are on back order until mid October.
I'd wait and get the new flat plane 02 ports. Better reading and if you are ever doing your own tuning, TTs, SEPro, PV, should help. V&H made the right move to cut down the 02 bungs.
Old Sep 10, 2012 | 01:39 PM
mkguitar's Avatar
mkguitar
the power duals can hit hard on right turns on a lowered bike.
hard enough to relieve traction from the rear tire- esp if there is a dip in the middle of a turn
just be aware of this- it is the cover over the X pipe that hits.
your bike is stock 1" lowered in the back already, if you lower the front too this could be a concern
( on a touring bike, the bottom of the fork cowbells is about 3/8" lower than the top of the fender- stock. if the forks have been lowered, they will be about 1 3/8" below).
also the clamp of the crossover needs to be oriented so that nothing is hanging down- like excess threaded rod, if the clamp cannot be turned cut the excess thread off.
this clamp can grab a speed bump an tear the exhaust off.
and the new torque spec for the tranny end cover bolts is 25 foot pounds
left is lowered, right is stock height.
the one on the left I almost lost it...
Mike
Old Sep 10, 2012 | 03:06 PM
glcash's Avatar
glcash
Good idea
Old Sep 10, 2012 | 04:03 PM
equandt's Avatar
equandt
I believe the Terry Comp unit uses your stock O2 sensors to measure and adjust the A/F ratio. I don't think it will adjust timing.
They aren't real popular but the guys that have them seem to think they are OK.
My brother has one on his dyna. The bike runs fine. I can't speak to the power it makes as he hasn't had it on a dyno...but I guess that is the point with the Terry Comp tuner.
Old Sep 10, 2012 | 04:10 PM
glcash's Avatar
glcash
I've never seen or heard if it until I seen it on my bike. Bike runs fine. Haven' had any issues. I'll leave it until it fails.
Old Sep 10, 2012 | 05:13 PM
bob2002's Avatar
bob2002
I had a Terry tuner on my 07 Ultra and I discovered after I replaced it that it worked as well as the power commander I used in its place did.My 07 was such a POS it was hard to tell what really worked.I would give it a chance what do you have to lose.
Old Sep 10, 2012 | 08:59 PM
vickers1's Avatar
vickers1
Here's my o2 sensors:
Attached Thumbnails Power duals question-162.jpg   Power duals question-166.jpg
Old Sep 10, 2012 | 09:43 PM
glcash's Avatar
glcash
Exactly what I was looking for
ron1z
Sep 15, 2014 09:53 PM
Nicky Pass
Feb 5, 2014 08:15 PM
ultraclassic53
Aug 13, 2013 09:44 PM
jcp0330
Oct 24, 2010 09:15 PM
dirtdobber
Nov 1, 2009 08:58 AM
