Tires?
Old Aug 17, 2005 | 04:04 PM
CaptnAl's Avatar
CaptnAl
Default RE: Tires?
Thx fo the heads up on the list of tools. I will also check out the site that you suggested.
I have a good compliment of tools, the torque wrench, manual ect., But wht 36 MM and 10 MM sockets. I have not run into mettic fasteners on the bike yet, unlike my truck which has half SAE and half Metric.
Old Aug 17, 2005 | 04:30 PM
TxMoores's Avatar
TxMoores
Default RE: Tires?
How about the great and almighty eBay??? I found a pair of new AVON VENOM tires (150/80-16 & 90/90-21") for $270 delivered to my door.... This guy's site The Motorcycle Parts Store has all kinds of new tires at great prices and 5,000+ sales and a 99.8% rating I am going to give them a try!! Wish me luck!!
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Old Aug 17, 2005 | 05:57 PM
CaptnAl's Avatar
CaptnAl
Default RE: Tires?
I had venoms on my last ride ( A valkyrie ) the bike handled well on the original dunlops but the Venom R's made that big ol beast handle lie a sport bike. The avons are soft and sticky and great for cornering, but they dont last as long.
Good luck i dont think you will have a problem.
Old Aug 17, 2005 | 05:59 PM
billnourse's Avatar
billnourse
Default RE: Tires?
Al,
The rear axle nut on the new Electra glides is 36mm. I damn near drove myself crazy trying to find a fit from the pawn shop one socket at a time. Finally called the HD shop to find out the right size. The 12 point bolts that hold the front brake calipers on are 10 mm, and it has to be a 12 point. The calipers have to come off to remove the front tire.
Regards,
Bill
Old Aug 17, 2005 | 06:03 PM
CaptnAl's Avatar
CaptnAl
Default RE: Tires?
Bill
Thanks, i would probably have done the same thing. I have the 12 point 10 MM, i will have to get a 36mm, I assume a 6 point will work? Also, do you recommend the HD belt tension gauge or do you have another kind that works as well?
thx
Allen
Old Aug 17, 2005 | 06:27 PM
edsaws's Avatar
edsaws
Default RE: Tires?
I change and balance my own tires and it isn't that bad of a job. One word of caution when purchasing tires on ebay or any online source is to ask what the date or code of when the tire was manufactored. Some of these people are triing to offload their old stock. I had good luck with www.ronayers.com
Old Aug 17, 2005 | 09:26 PM
billnourse's Avatar
billnourse
Default RE: Tires?
Al,
I have the HD tension gauge. I don't know if anyone else even makes one. The HD unit is about 15.00 I think. The 6 point 36 mm will work.
On the tires from AMT. I ordered Arleen's Saturday night and they got here today.
Regards,
Bill
Old Aug 18, 2005 | 10:02 AM
CaptnAl's Avatar
CaptnAl
Default RE: Tires?
Bill, picked up a socket last night after work, 9.95 out the door, ordered the tire , sent it groung so it probably wont be here util friday or monday.
What kind of tire tools do you use for removing the tire. I have an old set of Spoons that i was going to use but i am not sure about using them aginst the MAg wheel.
Any thoughts?
Allen
Old Aug 18, 2005 | 10:39 AM
pilot1996's Avatar
pilot1996
Default RE: Tires?
CaptAl,
If you don't mind doing another DIY thread, we would all appreciate it...check out your other one in the DIY section under Oil. Looks great!
Thanks again,
Mac
Old Aug 18, 2005 | 10:50 AM
CaptnAl's Avatar
CaptnAl
Default RE: Tires?
I can do that, ti will probably be the week end of 8/27 that i will do the change.
tHX For setting up the DYI on the oil temp gauge, looks good. I hope it helps others.
I will let you know when i get the next one complete.
thx
Allen
balingwire
Wheels/Tires
11
Jan 10, 2024 03:38 PM
rauchman
May 11, 2016 11:43 PM
Grandslam
Apr 29, 2013 06:57 AM
Fatboy Brian
Apr 4, 2010 07:34 AM
HDF Tech
Jun 30, 2005 01:54 PM
