Exhaust install question
Old Sep 18, 2012 | 03:36 PM
darkcustom48's Avatar
darkcustom48
Default Exhaust install question
So tell me if I am over simplifying this project. Starting with stock 2012 Road King classic.
1. Install new pipes
2. Install new mufflers
3. Install high flow air cleaner
4. Install V&H LCD fuelpak
5. Set fuel pack map code
6. Test ride
Am I in dream land or is this all I have to do. I am mechanically capable of this project.
Thoughts?
Old Sep 18, 2012 | 03:43 PM
aces25's Avatar
aces25
You got it, more or less. If you're going with a FuelPak, consider a common combo used by V&H. I would suggest going with a true tuner (Power Commander V, Power Vision, Thundermax, etc) rather than a FuelPak for a bit more flexibility.
Old Sep 18, 2012 | 03:53 PM
candave650's Avatar
candave650
Agreed,If you are going with V&H all the way then the Fuelpak should be OK for just Stage 1 mods.
Other tuners will be more flexible for future mods and you can have control of the map.
You can do the work yourself,just make sure you have a HD Service Manual.
Take your time,It's fun to work on your bike and gives you a great feeling of CAN DO!!!
Old Sep 18, 2012 | 04:22 PM
Garemlin's Avatar
Garemlin
I'd replace the Fuel Pak with the new Fuel Moto Dynojet Micro Tuner. Much easier to tune to your specific set-up. V&H is limited to what they have created maps for. It is a little cheaper than the Fuel Pak too.
http://www.fuelmotousa.com/microtuner.htm
Old Sep 19, 2012 | 10:12 AM
FenderGuy53's Avatar
FenderGuy53
6. Test ride
Thoughts?
Don't forget the anti-seize for the headpipe-to-muffler joints and muffler clamps.
Old Sep 19, 2012 | 10:18 AM
KCFLHRC's Avatar
KCFLHRC
Get new exhaust gaskets and a torque wrench. Oh yeah, and a 12 pack of Bud Light.
Old Sep 19, 2012 | 11:45 AM
mrfikser's Avatar
mrfikser
if you are going to take the exhaust off you might as well spend a little more and put cams in it...cams are pretty easy to install, I did it and used the original push rods to make it more reliable and save some money ....with the exhaust already off the cams only take about 2 hours to install even with opening the valve covers and loosening the rocker arms...then the bike will really come alive...
Apr 20, 2013 05:05 PM
stevemiller000
Jul 26, 2011 05:54 PM
JonnyD
Sep 1, 2008 08:52 PM
fivestar
Jul 17, 2006 05:14 PM
stevenk3101
Sep 25, 2005 06:35 PM
