Windshield loose
Old Sep 21, 2012 | 05:44 PM
wrench22's Avatar
wrench22
Did you buy the bike used? Did someone else install the t-bags?
If yes to either question, maybe someone changed the length of the screws.
Old Sep 21, 2012 | 05:52 PM
MontyCop05's Avatar
MontyCop05
Originally Posted by Texas Fat Boy
I'll bet those little brass inserts have pulled out some. When you use the pouches it is taking up the slack room.
Look and see if those brass insets are still flush wth the plastic fairing they are in.
The replacement inserts are about $1 and screw in. The stocks ones are pressed in at the factory.
Old Sep 21, 2012 | 06:34 PM
zoozoo's Avatar
zoozoo
Those brass inserts from the factory suck. I need to change one on my batwing.
Old Sep 22, 2012 | 01:09 AM
fxdxruss's Avatar
fxdxruss
HD has a repair insert for the batwing. When I did my center insert I drilled and I think I used a tap, I do however rember thinking that just trying to thread the replacment part in w/o enlarging the hole would be a mistake and could crack the plastic.
Russ
32roadking
Jan 22, 2015 02:05 PM
dburgjohn
Mar 13, 2014 11:31 PM
67wizard
Jul 15, 2012 12:06 AM
soundman
Mar 26, 2010 10:11 PM
minordl
May 6, 2008 09:40 AM
