Trailering Ultra
Old Sep 22, 2012 | 03:06 PM
2heritagespringers's Avatar
2heritagespringers
Default Trailering Ultra
Have to have bike trailered 3000 miles. Should I let all air out of rear shocks or leave 10-15 lbs in them. Bike will be tied down for approx 2 weeks.
Thanks
Old Sep 22, 2012 | 03:22 PM
mkguitar's Avatar
mkguitar
leave the air in.
tension the straps so that there is some compression on the suspension.
I usually put a cable tie on the brake lever "lightly" and the bike in gear.
take into account that when driving you can always control how quickly you accelerate and how quickly you corner- but you may not be able to control how quickly you have to stop.
make sure the bike cannot shift forwards on you
Mike
Old Sep 22, 2012 | 03:25 PM
HogglyWoggly's Avatar
HogglyWoggly
When I trailer mine I secure the front with rachet straps and only tie the back to keep it from moving side to side. Shock pressure shouldn't make much difference.
-Hoggly
Old Sep 23, 2012 | 11:51 PM
Geets's Avatar
Geets
Every trailer is unique when it comes to securing a bike. There are youtube videos out there that may help you visualize it.
Old Sep 23, 2012 | 11:59 PM
drukanfu's Avatar
drukanfu
3000 Miles ! .........I'd tie it down like a bondage freak !
Old Sep 24, 2012 | 12:31 AM
NDBadlands4-2's Avatar
NDBadlands4-2
-Hoggly
Thi is what I do. I have never messed with the rear shock pressure.
Old Sep 24, 2012 | 01:33 AM
equandt's Avatar
equandt
I would suggest putting a wheel chock in the trailer to help hold the bike upright then use your rachet straps to secure the bike. I compressed my front shocks about half way with the pressure from the straps. As others have said, the rear straps are just to keep the bike from moving side to side, very little pressure was on the rear suspension.
I used the Harbor Freight black wheel chock. It worked like a champ. I used a couple wood screws to secure it to the trailer floor and some 4x4s to block it in the front.
I used this technique when I pulled my bike from Wisconsin to Daytona last year for bike week. That was 2600 miles round trip on the trailer.
Good luck.
Old Sep 24, 2012 | 02:30 AM
mccstevie's Avatar
mccstevie
Thanks
I also recommend the Harbor Freight wheel chock. You can get it with a coupon out of most biker mags for $45. Wrap a soft tie around the forks above the fender mount and ratchet strap to the chock eyebolts. I also had straps from Harley chrome mounts on top of forks with little compression on the shocks but felt they really weren't needed,just a precaution. Also ratchet straps from rear floorboard mounts toward rear or sides. Towed 3000 miles this August and it never moved. I used 1/2 " bolts through floor with a backing plate under the trailer just to make sure the chock didn't move.
Old Sep 24, 2012 | 10:19 AM
soniccbr's Avatar
soniccbr
Wheel chocks are a good thing. Two straps front and two straps rear. Do not leave the stand down or trans in gear.
israeldon
Jul 7, 2011 04:03 PM
sgoharley
Nov 20, 2009 08:08 PM
hartk1
Oct 23, 2009 09:22 AM
mcman
Aug 20, 2006 11:11 AM
morespl
Feb 25, 2006 02:48 AM
