Loose Shock Bolts
Old Sep 23, 2012 | 07:44 PM
boatwake's Avatar
boatwake
Default Loose Shock Bolts
Has anyone ever heard of the top bolts on the rear shocks of FL bikes coming loose? I was riding this weekend. Someone following me told me that they thought my saddle bag looked loose. Everything looked tight, but then I noticed the top bolt on the shock looked loose (I could spin the lock washer with my finger). Both sides were loose, but one was really bad.
The only service I can think of that may have involved the shocks was about 2K miles ago when I had a new rear tire installed. It seems a stretch, but I have no idea what all the dealer may loosen or remove to change the rear tire.
The thought of the bolt coming out completely kind of rattled me. I had been riding 2-up with my wife on the interstate, cruising about 70. Not sure how much control I would have had if either of those bolts would have come out.
Old Sep 23, 2012 | 07:54 PM
Keithhu's Avatar
Keithhu
Maybe those arent "critical fasteners", LOL. I'll definitely start checking them now!
Old Sep 23, 2012 | 08:01 PM
mkguitar's Avatar
mkguitar
in most cases to change a tire, the bike is put on a lift with a drop out rear section- the axle is pulled and the wheel drops out the bottom of the bike and is reinstalled by being lifted up into place.
so the upper shock bolts shouldn't be touched.
never had mine come loose, but I do grab and pull on my shocks as part of the check on wash day
mike
Old Sep 23, 2012 | 08:07 PM
iwillfixthem4u's Avatar
iwillfixthem4u
it is a common practice to remove shock bolts to get to the axle bolt without removing the exhaust
Old Sep 23, 2012 | 08:19 PM
boatwake's Avatar
boatwake
Good info, thanks! The lock washer looks substantial, so I wouldn't think they would loosen if torqued down correctly. I hate to point fingers, but I'm having a hard time believing they would loosen on their own.
Old Sep 23, 2012 | 09:08 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
This happens alot because some mufflers make it impossible to get the axel out so either the muffler has to come off or you drop the swingarm down by taking the shock bolts out. However when I was doing it, I always took the lower bolts out.
Old Sep 23, 2012 | 09:11 PM
blue flht's Avatar
blue flht
Blue threadlocker just a few drops, your best friend.
Old Sep 23, 2012 | 09:22 PM
VinnyM's Avatar
VinnyM
On my 11 RKC both uppers were loose when I got it home brand new.
Old Sep 23, 2012 | 11:16 PM
boom23's Avatar
boom23
Blue threadlock... I use it on everything that Harley says not use threadlock... Easy peace of mind.
Old Sep 24, 2012 | 08:42 AM
boatwake's Avatar
boatwake
Sounds like there's enough uncertainty that I just need to bite my tongue with the HD dealer service department (for now) and do a better job inspecting my bike, especially after a servicing :-)
Unfortunately, the only problems I have ever had with my Street Glide have shortly followed a servicing. I might try another dealer just in case the grass is truly greener on the other side.
Thanks everyone.
