Installing Power Vision cable on 2013 ultra?
Old Sep 29, 2012 | 08:44 PM
Reaper22's Avatar
Reaper22
Default Installing Power Vision cable on 2013 ultra?
I installed the cable to the power vision thru the tank console and once console was mounted back on I tugged on cable both ways to see if it wasn't binding or pinched and it pulled back and forth with some but not a whole lot of resistance, Out the bottom of console thru frame and thru the side of fuse panel to the diagnostic port, Out the top of console next to the console mounting bolt then up thru the ignition switch housing to the power vision.. Just wundering how anyone else run their cable and it this ok to leave, console is back down on tank without an issue,
Old Sep 29, 2012 | 10:42 PM
Harlay Hawk's Avatar
Harlay Hawk
I removed my tank and put it under the tank, wiretied it to the factory harness that is already run there and working fine.
2011 Ultra
Old Sep 29, 2012 | 10:55 PM
drukanfu's Avatar
drukanfu
Over the hill and through the woods....works for my GPS as well. Under the console is fine.
Maxxsmart
Aug 20, 2016 04:21 PM
Andrea Capello
Apr 21, 2015 04:57 PM
SoCalMike
2014-2024 Touring Models
11
Oct 11, 2014 09:36 PM
keno
Aug 28, 2013 03:31 PM
shorty1
May 28, 2008 10:31 AM
