Damn SE Comp!!!!
Old Oct 3, 2012 | 03:58 PM
  #31
soft 02's Avatar
soft 02
Originally Posted by NELS
I don't see how that is possible as the springs are spring washers that face each other , two sets look like this () and one single washer that faces out (. So the whole setup looks like this () () ( . Maybe they did something on the stock comp that has a coil spring.
Took it apart today and light wear but nothing obvious so when it stops raining I'll warm it up to see how it acts. If I have the same problem I'll go back to the stock. I think I can add a washer under the coil spring to increase pressure.
They double up on the last single cone spring. I dont have an issue with mine so didnt need to do this.
Old Oct 3, 2012 | 04:00 PM
  #32
NELS's Avatar
NELS
OOPS!! Sorry , thinking about the wrong setup as the stock comp has spring washers also. Sorry if I misled or confused anyone.
Old Oct 3, 2012 | 04:01 PM
  #33
NELS's Avatar
NELS
Thanks , maybe next trick!
Old Oct 3, 2012 | 05:54 PM
  #34
1fathog's Avatar
1fathog
08a has oil grooves cut into the washer
Old Oct 3, 2012 | 05:57 PM
  #35
NELS's Avatar
NELS
Thanks for the reply , now, which washer? The outer fiber washer has grooves in mine , is that the one?
Hog happy
Aug 11, 2015 01:48 PM
rbferg
Apr 23, 2014 01:03 PM
SteveUltra
Oct 10, 2013 03:17 PM
harley_jeff
Exhaust System Topics
Dec 29, 2011 10:21 PM
jrudicel
Sep 1, 2011 11:43 PM
