Audio Freaks
Old Dec 9, 2012 | 09:03 PM
  #41
0ldhippie's Avatar
0ldhippie
Just hook both right speaker wires to the right amp output and both left speaker wires to the left amp output = 2ohm parallel hookup.
Old Dec 9, 2012 | 10:19 PM
  #42
floridapoolboy's Avatar
floridapoolboy
Series hookup is R1+R2, parallel hookup is a bit more complicated. When running speakers in parallel it's R1XR2 divided by R1+R2. In this case running 4 ohm speakers in parallel would be R1 (4) times R2 (4) =16 ohms, divided by R1 (4) plus R2 (4) = 8 ohms. 16 divided by 8 equals a final impedance of 2 ohms.
Originally Posted by MarcV125
Hey guys just an update..i received my amp and have her installed, im just waiting on my back ordered Hertz hcx165's, but anyways it has given me some time to research this whole audio stuff a little more and have a question. So i ordered two sets of the Hertz speakers, both are 4 ohm. The amp is 2 channel 2 ohm rated. It says on the Biketronics website that it "Will power four, 4 ohm speakers connected in parallel". Now if you connect 4 , 4 ohm speakers in parallel wouldn't the impedance drop to 1 ohm? or is my math wrong in this case?.. And that obviously wouldn't be optimal to power these speakers?... must be missing something lol.. Again still learning this stuff so it may be very simple and i could be completely wrong lol..
Thanks again
Marc
Old Dec 9, 2012 | 11:10 PM
  #43
jefla's Avatar
jefla
Can someone help me determine how long I can run my cd player off the battery then start the bike, assuming a good battery? I (currently) have the HK head unit driving a HogTune 70.2 and Focal PC 165s.
Old Dec 10, 2012 | 06:42 AM
  #44
UltraNutZ's Avatar
UltraNutZ
Thanks again
Marc
Marc, don't over think this bud.. the way this works; by connecting 2 - 4ohm speakers in parallel (2 for each channel of the amp, right and left) brings the load the amp will see to 2ohms. You are good to go in this configuration. But to answer your first question; yes wiring 4 - 4ohm speakers in parallel would in fact give you a 1ohm load. This is not the way you'll be wiring this up as you'll only be using 2 speakers per channel.
Old Dec 10, 2012 | 06:46 AM
  #45
UltraNutZ's Avatar
UltraNutZ
4 hours, 32 minutes, 12 seconds!
Dude really.. if in doubt, don't.
Old Dec 10, 2012 | 08:03 AM
  #46
flhxmc's Avatar
flhxmc
Originally Posted by 0ldhippie
I have my JL xd100/4 mounted in the fairing but if ya have a tourpac ya can mount a bigger amp under it like Harley does.
You kind of bummed me out! I have been a long time JL fanatic when I used to be into car stereo. Just recently upgraded my street glide and went with the Arc, am very happy with it but if I knew the JL would fit in there I would have went with that!
Mike
Old Dec 10, 2012 | 11:51 AM
  #47
chevele72's Avatar
chevele72
Help me out here, the Polk Audio's say on the website and Crutchfield that they are 4 ohm, everyone says they are 2.7 (or so) ohm. What am I missing?
Can I wire those in parallel or series with a pair of Hertz to work with an Arc 2 channel?
Thanks.
Old Dec 10, 2012 | 12:19 PM
  #48
UltraNutZ's Avatar
UltraNutZ
they are not 4 ohm.. they are actually 2.7 ohm speakers.
Which Arc amp and which hertz speakers do you currently have?
Old Dec 10, 2012 | 12:30 PM
  #49
floridapoolboy
Polks come in several impedances, the DB and DXI lines are 4 ohm, the MM line is 2.7 ohm, and the MM Ultra Marine line is 4 ohms. Running 2.7 ohm MM speakers in parallel with 4 ohm Hertz speakers will give a final impedance of 1.6 ohms, which might cause problems with a 2 ohm stable amp. Best to call the manufacturer to confirm that you won't overstress the amp.
Old Dec 10, 2012 | 01:40 PM
  #50
chevele72's Avatar
chevele72
Hertz HCX 165 Hi Energy 6.5's from Biketronics, and Polk Audio DXI 650's. ARC 125.2
Thanks !
