how do I remove plug from headlight
Old Oct 7, 2012 | 09:12 PM
SMsgt Tom's Avatar
SMsgt Tom
I had the same problem last week. Tried everything. There are 2 push lock releases on the plug. I finally popped the back off the plug and found the locking pin broken. Since the dealer had to remove the outer fairing to install the NIM, I suspect it was damaged then. A small screwdriver released it and the plug slid right off.
Old Oct 7, 2012 | 10:01 PM
Bushy's Avatar
Bushy
I had the same problem...twice I had issues, now I have a Truck lite 7 and no more issues
Old Oct 7, 2012 | 11:20 PM
SugsPa's Avatar
SugsPa
Had the same problem. I wanted to inspect the fairing bracket tabs. Was able to check them without removing the headlight.
SugsPa
Old Oct 11, 2012 | 05:49 PM
geezerglide48's Avatar
geezerglide48
5th Gear
Thanks for everyones input. How did I miss those @#$%$ tabs on the side? What is frustrating is the service manual did not say a thing about squeezing the tabs. I can expect that from a Haynes automotive manual but you would think that a H-D service manual would be a little more detailed. Maybe its so simple that most mechanically inclined persons would figure it out before ruining there bulb. Anyway thanks. And on to upgrading my stereo system. Trying to put speakers in my lowers and my saddlebags. What can I say, I love my music. It aint the same without some good tunes blaring out my speakers. Can't wait till I get it all hooked up.
hscic
Mar 7, 2019 11:13 AM
Fredsharley
Aug 24, 2016 04:09 PM
skullhead
May 19, 2008 10:57 AM
Bacon_Grease
Mar 16, 2008 08:06 PM
swipter
Sep 28, 2007 01:16 PM
