How much oil?
Old Jan 27, 2007 | 08:11 AM
Capt.Bob's Avatar
Capt.Bob
Default How much oil?
I just changed my oil for the first time in my 06 Ultra. I read somewhere on this fourm to put back 3 1/2 qts. of oil. I did and it was not as much as I drained out. My manual says 4 qts. how much is right? How much do ya'll put back in? Thanks
Old Jan 27, 2007 | 10:02 AM
Keystone's Avatar
Keystone
Default RE: How much oil?
Put 3 1/2 quarts in. Run it for a few moments to fill the oil filter and lines. Then re-check it and add if you need to.
Old Jan 27, 2007 | 10:14 AM
coolnite's Avatar
coolnite
ORIGINAL: Keystone
I second what Keystone says.
Old Jan 27, 2007 | 11:11 AM
maineultraclassic's Avatar
maineultraclassic
For sure, start with 3 1/2 quarts. The last thing you want to do is overfill it......you'll have oil coming out the air cleaner in no time.
I usually end up around 3 2/3 - 3 3/4 quarts, that puts it right on the money with the dipstick.
Steve
Old Jan 27, 2007 | 11:16 AM
electaRICK's Avatar
electaRICK
your doing a oil change?? and dont know enuff to look at a dipstick????
think about it??
Old Jan 27, 2007 | 11:17 AM
xxxflhrci's Avatar
xxxflhrci
I've been dumping in 4 quarts for years now. I don't get any out the air cleaner.
Old Jan 27, 2007 | 11:31 AM
2005UltraNC's Avatar
2005UltraNC
I end up using all 4 quarts - with oil filter replacement. But, yes, start with 3.5 and move up. On kickstand, hot engine to top of fill line. Cold engine to middle of fill lines.
Old Jan 27, 2007 | 12:48 PM
bay13's Avatar
bay13
The engine holds 4 quarts. You dumping the oil doesn't get the "entire 4 quarts out" so the put 3.5 in and then ride the bike to warm things up and top from there is the way to go.
Old Jan 27, 2007 | 02:35 PM
stglideblk's Avatar
stglideblk
4 full qts in mine w/filter
Old Jan 27, 2007 | 03:18 PM
BirchwhiteHD's Avatar
BirchwhiteHD
same here,4 quarts w/filter change
