new lifters
Old Oct 9, 2012 | 04:14 PM
joee's Avatar
joee
Default new lifters
witch lifters would be best and quiet in 2012 103 when i do a cam change planning on putting in a zippers red shift 577-hs and having bean do the heads
thanks
Old Oct 9, 2012 | 04:26 PM
mkguitar's Avatar
mkguitar
maybe ask your head guy.
hydraulic lifters use oil to attain their full length- if pressure problem or the lifters "bleed down" proper length is lost and parts'll clatter around
solid lifters are pretty much at length ( allow for expansion though) and stay at length but are not suitable for all cams--- and pretty much a hold-over from pre-historic days.
length; remember that expansion rates in an air cooled motor are more extreme than in a liquid cooled- the entire cylinder will grow "taller" as it warms and correct operating tolerances are reached ( which is why we don't want to hammer a cold motor, leaving off when the heads are warm to the touch and taking easy the first 5 or 10 minutes is good.
noise ? it is subjective.
for new riders they have trouble getting used to sitting on top of a motor and all the sensory experiences that come with that.
a windscreen/fairing will reflect extra noise back at you. thighs to the tank will help to block noise.
the best lifter is the one which will complement the cams chosen and the valve springs.
head guy should be able to help
mike
Plasteredcat
Engine Mechanical Topics
Jul 29, 2015 09:19 PM
Scrmnvtwins
Jul 10, 2015 06:10 AM
CT-Bagger
Exhaust System Topics
Sep 12, 2014 12:03 PM
dale8287
May 21, 2014 01:11 PM
Chopperbob
EVO
Sep 17, 2012 07:47 AM
