Major THROTTLE issues.... please help!
Old Oct 14, 2012 | 12:28 PM
traveler's Avatar
traveler
At some point the sensor in the grip may go bad....?
Old Oct 14, 2012 | 01:38 PM
mrfikser's Avatar
mrfikser
the fretting is known issue...I would say, because of all the different codes that it is probably a voltage problem going to the control module....when the voltage drops or spikes it thinks all kinds of weird stuff is going on....so, check your voltage at the battery and the battery itself (load test it) ...also check the output of the regulator for either high or low voltages...
Old Oct 14, 2012 | 01:42 PM
TXCOMMISH's Avatar
TXCOMMISH
Buddy of mine just went thru this. Mechanic said it's almost never the grip sensor. Almost always the throttle body/actuator connector. YMMV.
Old Oct 14, 2012 | 05:09 PM
PappyUSMC's Avatar
PappyUSMC
It has a brand new twist grip. So it is definately not that.
Old Oct 14, 2012 | 06:19 PM
PappyUSMC's Avatar
PappyUSMC
Ok, I went out and started playing with the bike.....
If I shake the ECM/ECM Connector... or barely START to release the latch on the ECM connection, it throws all the codes I listed before. So I am guessing it is the Fretting issue.....
Now.. can anyone tell me the way to fix it? Maybe with Pics?
Old Oct 14, 2012 | 07:36 PM
traveler's Avatar
traveler
Okay, Gunny, do me a favor, and keep us up to date on this.......I hope mine doesn't start acting up.
~Joe
Old Oct 15, 2012 | 05:09 AM
Steel Wheels's Avatar
Steel Wheels
GM had a bulletin on injector connector fretting a few years ago that advised dressing the terminals with dielectric grease. Never saw problems after that.
Old Oct 20, 2012 | 09:44 AM
Rick06's Avatar
Rick06
Pappy,
Since the pin contacts are molded into the EMC I had to replace the EMC. The terminal and wire in the mating wire harness that goes between the EMC and the Throttle Acuator had to be replaced as well. The wire terminal can be pushed out of the connector harness at both ends and replaced with a new wire and crimp terminals at both ends. Then dressed through the cable harness. Connector types and terminals are listed in the Service manual. Use Dielectric grease on all contacts when done. The grease helps lubricate and seals the pins preventing this from happing again. If there is already freeting I don't think that just applying grease will do much good. The terminal is gold plated and the fretting increases the resistance at the connection. The ECM is looking at a small (millivolt) difference and any increased resistance changes the value read at the EMC.
Old Oct 20, 2012 | 09:49 AM
traveler's Avatar
traveler
good idea.....need to get some dielectric grease.....good winter project...unplug the ECM at the throttle body and grease them up!
~Joe
Old Oct 22, 2012 | 07:09 PM
PappyUSMC's Avatar
PappyUSMC
Just got done talking to Harley when I picked up the part number items for the fretting issue.
Their telling me the only thing I can safely use to crimp these new conenctors is a Harley only crimp tool that is only available to dealers.???????
Does this sound right????
