Has the cam been changed?
Old Oct 22, 2012 | 10:35 AM
GaCracker63's Avatar
GaCracker63
2nd Gear
Default Has the cam been changed?
I bought a used 2001 Road King this year, and I know some work has been done on it but not sure what. It has had air cleaner changed to open back up, has a power commander on it, and the push rod tubes are changed with adjustable push rods. The bike only had 14000 miles on it and runs very strong. I am trying to fiqure out if the cams have been changed also. I also want to see how to change the pc program it runs a little rich.
Old Oct 22, 2012 | 10:46 AM
lionsm13's Avatar
lionsm13
Find out who the previous owner was, or where they bought it from.. and go from there.
Old Oct 22, 2012 | 11:00 AM
BIGVTWIN's Avatar
BIGVTWIN
More than likely if head work has been done then it has cams put in it. Head work is expensive compared to cams in the grand scheme of things.Also head work on a stock cam wont get much bang for the buck compared to a more aggresive cam and head work.
I am assuming that it has a higher flow intake?
Old Oct 22, 2012 | 11:35 AM
scj's Avatar
scj
Kind of a PITA but most cams are stamped so you could always open it up and look.
Old Oct 22, 2012 | 03:17 PM
GaCracker63
2nd Gear
I don't think the heads have been off just lifter blocks and cam plate. I figured the oil pump was changed and because of low miles I am thinking proble put cams in it. I had it put on dyno and its pushing 90 ft lbs and over 80 horse power.
Old Oct 23, 2012 | 07:24 PM
roaddr's Avatar
roaddr
With them numbers the cams have been changed. My 06 ultra classic has stage 2 AC, V & H duals, PC, stock cams for now and is in low to mid 70's HP & TQ. Guy I got it from had it dyno tuned and I have the sheet.
Old Oct 23, 2012 | 07:42 PM
EG-2006's Avatar
EG-2006
You could plug in to the power commander and look at the map. The power commander file has a notes section at the bottom of the screen. When I had a PC3, like most others, I used the notes section to keep track of what map I had and what setup it was for. It might tell you exactly what you have but to be sure remove the cam cover and look at the ends of the cams.
I have an 06EG with the stock 88ci, Andrews TW21 cams and dyno tuned and I am running the same hp/tq that you have.
Old Oct 23, 2012 | 08:42 PM
Lowcountry Joe's Avatar
Lowcountry Joe
If you are seeing adjustable rods, then the probability is pretty good that the cams have been upgraded. If they had done head work, it's likely that they would have went back with solid rods since they would have the top end off anyway. Just my opinion.
Old Oct 24, 2012 | 07:47 AM
GaCracker63
2nd Gear
Thanks for that, now my question is how do I get into the pc3 I don't have a program for it. Can I down load one or do I have to?
evhid1
Engine Mechanical Topics
14
Jul 22, 2017 06:27 PM
06Cummins
Jul 23, 2014 02:00 PM
kmontague
Oct 4, 2010 10:49 AM
young n bag'n
Exhaust System Topics
17
Mar 6, 2010 09:39 PM
HDF Tech
Jun 25, 2005 12:59 AM
