Mysterious trany leak
Old Nov 19, 2012 | 10:06 PM
Ron "Gunner" Retzlaff's Avatar
Originally Posted by DPete
He means the very bottom 2 bolts on the tranny trap door that have the exhaust bracket
I had this problem myself and used a small allen/ratchet handle. I didn't have to remove the exhaust or use ball allens to tighten them up. I removed the bolts, put some locktite on the thread and ran them back in. No more leak and I've put lots of miles down on her since the repair.
Old Nov 19, 2012 | 10:10 PM
mcain49's Avatar
mcain49
Originally Posted by Lowcountry Joe
As I recall there is also a new, higher torque spec for the header hanger transmission cover bolts. It went from around 14 ft lbs to a little over 20. Dawg probably knows.
I had those bolts back out on my 2010 and cause a leak. Tightened them temporarily with the ball end Allen, then when I did my header changeout, I replaced them entirely with hex head bolts with lock washers and red locktite. I installed them with the old torque spec of 14 ft lbs, but it's still tight and holding after thousands of miles.
Get yourself a good light, those leak sources are tricky sometimes.
My 10 Ultra was leaking from the transmission cover bolts. Still under warranty so I took it to the dealer. They said the torque specs have changed on the transmission cover as well as the oil pan bolts.
Old Nov 20, 2012 | 10:14 PM
K00LJerk's Avatar
K00LJerk
Yep just fixed a tranny leak tightened the two header bracket bolts. strange how they bolt into the tranny resevior.
Old Jan 13, 2013 | 06:05 PM
kentuckyjeff03's Avatar
kentuckyjeff03
6th Gear
yea right you thing those high dollar knuckle heads would have made that a dry hole !
will fix mine the right way myself
glcash
Aug 27, 2012 12:13 AM
UltraJim
Jan 23, 2012 12:25 PM
87HDFXSTC
EVO
11
Oct 16, 2009 05:26 PM
03eglide
Jan 5, 2009 05:00 PM
1peter
Sep 20, 2007 04:23 AM
