Also states in owner's manual to NOT use any aftermarket parts - must be lots of people that skip that page...
My Owners Manual says about using parts other than HD .
pg 165
*Harley-Davidson cautions you against the use of non-standart parts such as aftermarket and custom made extended front forks which may adversely affect performance and handling. The use of any non-standard parts including mufflers may void your warranty according to terms of the warranty. Removing or altering factory installed standard parts may adversely affect performance which could result in death or serious injury.
I think that covers it regarding after-market parts. (mostly for warranty purposes).
Oh wait a minute -- You mean the "I'm picking up my bike from service and I'm wondering why my bike won't start" switch? Or the "I'm riding under a tunnel and I'm going to make the bike backfire to shoot flames out of my pipes" switch?
Granted -- I don't think the "flame backfire" thing works with the EFI's, but they'll still pop nicely. On my old blue RK, it shot flames out nicely.**
Anyway -- I never use it. Heck, on my old metrics (Yama-Hondas), even the service guys would tell me never to use it. "Remember it's there in case you need it, but don't use it" is what they usually said.
** For the uninitiated, if you're "at speed" and there's at least some drag on the motor, if you flip that switch off/on once quickly, there's a very good chance you'll get a nice "POP" from it -- If carbed, a potential "flame pop" which is fun for the guys behind you. The pop itself is great if you spot wildlife up ahead and usually sends them running for cover.
Back in the day it was a kill button. A momentary button like a horn, 68 sportster, no battery to drain, kick start, choke, magneto, advance and retard the spark. shut her down with the kill button.
So I use the kill switch and then the ignition. Got to be your routine, not sure about any issues just using the ignition switch, but I don't think there would be any.
I have the factory security system with Smart Siren II alarm. If I use the ignition switch to shut off the motor I have exactly 4 seconds to plant the bike and dismount before it is activated. I don't like to be rushed, I use the kill switch! Then when I shut the rest of the bike off with the ignition switch I turn it straight to fork lock.
What year is the manual you are looking it? When I wrenched at a dealer years ago we were having this discussion with our regional dealer rep (08 or 09) and he was saying that they were trying to get the manuals shut down procedure changed. Not sure if they ever did or not.
The main thing to know if you are using your run/kill switch to shut off your bike is to let the bike come to a complete idle before killing it. There was a service bulletin back in '08 for high idle problem, they bulletin had us cycle the ignition on and off several times to get the idle to re-set. What was happening is people were killing their bikes with the run switch and not letting the idle settle down, if the 2 sensors I was referring to in my earlier post (TPS and TGS) don't equal 5 VDC between them they they will reset to what it was last know. In other words if you soft kill your bike (run/kill switch) and the bike is not at a normal idle the 2 sensors might be adjusting and not be at 5 VDC, it can result in an ab-normal idle and need to be re-set. Worse case scenario it can put your bike into limp mode.
Actually unless one of the sensors is damaged they will ALWAYS read a 2.5v average regardless of the throttle position. Think of it this way at full throttle sensor one reads it's maximum and sensor two reads its minimum on a 1 to 5 volt scale. At idle they are reversed. it's a redundant safetyfeature, two sensors with three monitored outputs. All have to agree or the ECM envokes the dreaded limp home mode. The idle issue you are referring to is a glitch in the ECM taking a throttle reading at engine shut down when the engine isn't at idle.
By the way welcome to Fredericksbug, I'm going to come down and check out your shop one day soon.
The engine "Run" "Off" (or kill switch) only does half the job. Why get in the habit of doing just half a job? The MSF teaches it to new riders because it's in the same place on all motorcycles. No matter what bike they ride after that, they know how to shut the engine off; all while never having to take a hand off the bars. As with any training designed to meet the needs of the least proficient; it leaves something to be desired.
My guess is the MSF gets a kickback from battery manufacturers
The way it was explained to me is that the voltages are constantly changing and when you use the kill switch it doesn't shut everything off simultaneously like using the ignition switch, so if the TGS loses power a microsecond before the TPS sensor it can throw it out of whack, or vice versa. I just know that we don't have idle issues in customers bikes that only use the ignition switch.
Why do they only use a master ignition switch in cars?
Thanks for the welcome, my wife and I are really enjoying the area, hope to see you soon. It's always great meeting people from the forums.
Well, I've done it again, cut off the King via the kill switch on the bar and forgotten to turn off the tank-mounted switch, leaving the lights on & killing my battery! When I bought this in '09 the salesperson told me that I shouldn't leave the bar-mounted kill switch on b/c it would drain the battery, and I needed to use them both.
that's BS. there are other reasons (TBW bikes) to turn off the run/stop switch but that ain't one of them and then some of those reasons are debatable because of the issues it causes, ie. remembering where your throttle position is when turning it off.
Originally Posted by smokewagon
I mostly remember to use both switches, but on average I forget and have drained battery issues at least twice or three times a year.
Can I just leave the kill switch on and only mess with the tank-mounted, or will that really give me trouble with draining the battery??
That run/stop switch has never been used on any bike I've ever owned that had the multiple switch setup and I've never had a single issue with doing so.
If you're going to use that run/stop switch. Make sure when you pull up and stop and are ready to turn it off, your hand is 100% OFF the throttle.
