Any guesses ????
Old Nov 4, 2012 | 11:34 AM
springer 03's Avatar
springer 03
Originally Posted by ultraclassic53
So I dropped the bike off. I specifically asked why he wanted to deck the heads vs doing pistons. His answer was that it allowed him to control compression. He wanted to be in the 9.7 - 9.8 range. He said that there wads less chance of ping and that if you get somewhere that you can't get hi octane gas it would run better.
I think that compression is pretty low and IMO 10.5 would be a better number to get more performance.
Old Nov 4, 2012 | 11:59 AM
tekeum's Avatar
tekeum
From my research you can get more performance from a 103 stage 4 or FM 107 for less money. If it were me I'd do the FM 107 they can set it up based on how you ride and what your end goals are.
Old Nov 4, 2012 | 01:55 PM
cruzmisl's Avatar
cruzmisl
he said he would talk to some guys and get back with me. I take it he has been doing this for quite a while. He has a guy that does heads for him and a Dyno guy locally that he uses.
That doesn't inspire confidence with me. If he's so experienced (and he may well be) why does he need to consult with anyone? If you went to a Doctor for a standard procedure would you let him do surgery if he had to check with other Doctors on the correct approach? I think not. I'd go to the Doctor he's asking.
A good engine builder will/should ask what you want, what your budget is and make suggestions based on other builds they've done and had success with.
That basic build info should roll off his tongue. I think you have too many Chef's in the kitchen on this one and they're not in the same shop. Head guy, dyno guy and assembly guy will all point fingers at each other when it doesn't work out as planned.
My 2 cents..........
Old Nov 4, 2012 | 03:27 PM
ultraclassic53's Avatar
ultraclassic53
And I can appreciate it.......
There's always those guys that know everything, their way is the only way, that are so smart they consult with know one...
By the way, I'm in health care... Doctors always consult with specialists and get second opinions. There is something called the health care team ...
There are also people thar sit around and look for negative things to say about other people.
The good news I feel sorry for them but thats about it because I certainly don't care what they think.
Old Nov 4, 2012 | 03:39 PM
scj's Avatar
scj
He's starting with a 110" engine.
I hope your bike runs great afterwards and I don't mean to bust your chops but I hate to see you end up with something that constantly needs attention.
I have a friend that did the exact mods as you (except cams) to a '12 CVO SG and he is constantly fighting a hiccup or miss.
Correct pistons (many aftermarket pistons available for any compression you desire) and head work would be a preferred method for my bike.
Old Nov 4, 2012 | 04:17 PM
Jinks's Avatar
Jinks
Dropping the bike off this morning.
I have a 2013 CVO Road V&H Power Duals, monster rounds, SE Tuner.
My last Dyno was 89.48 / 104.86.
Going with S&S 570 cams, Heads ported and polished, Decked and .030 gaskets. and a good tune.
Any guesses on final numbers ????
No serious guess on final numbers, but I took a look at the 570 cam specs. versus the cams I've used. I usually don't like to push the lift numbers for a road bike much over .520, but .570 isn't bad. Duration & overlap are reasonable, so I don't see any real problem. Mike's right about angle changes when decking the heads, but it's a pretty small change. You might experience some intake leaks, but usually you can cure them by puttin' a little gasket sealer on the new intake gaskets. Since your builder is tryin' to keep compression below 10:1 you should have a real rideable bike. I have a 10.5:1 that is rideable....if you want to go fast. Not so much in school zone traffic.....<shrug> It's your bike, build it your way. & let us know how it comes out.
Old Nov 4, 2012 | 04:50 PM
mgmmgm's Avatar
mgmmgm
Fuelmoto has some dyno sheets with CVO 110 using Woods cams.
tbonetony06
Mar 15, 2014 02:50 PM
FLYER
Dec 21, 2013 03:51 PM
chgofirefighter
Jul 17, 2013 03:11 AM
death trap
Exhaust System Topics
24
Nov 9, 2012 09:23 AM
DeneFXDWG
Nov 3, 2011 10:06 PM
