Starter replacement
Old Nov 5, 2012 | 10:23 AM
Skip's Avatar
Skip
Default Starter replacement
Need to replace the starter on my 2005 FLHT. Is there a gasket that goes between the starter and the primary housing? Looked at Ronnie's online parts book and can't tell. Thanks
Old Nov 5, 2012 | 11:14 AM
03dragonRK's Avatar
03dragonRK
There is a seal that is in the inner primary that the starter nose goes through. If it is not leaking no need to replace. You will see it once you remove the outer primary.
Old Nov 5, 2012 | 11:40 AM
Skip's Avatar
Skip
Thanks. I saw the seal in the parts book, just wasn't sure if there was also a gasket.
Litten Racing
Jan 14, 2025 07:32 PM
schoolmaster
EVO
Jan 13, 2025 08:22 PM
jurgie
EVO
Apr 20, 2019 07:11 AM
Scorpio09SG
Jul 24, 2015 03:58 PM
onionfmr
Jan 14, 2010 08:44 AM
