Loose Rear Shift Linkage Arm
I'm sure that I am not the first to have this problem so I figured I'd throw this question up on the forum. I recently purchased an '89 Ultra Classic. Upon going through the bike seeing what I needed to replace/repair I came across some additional play in the shift linkage. After looking at the situation I noticed that the rear linkage arm (the one that attaches the tranny shift rod and the upper shift linkage) is worn and loose. Scared to ask this question but, do I need to take the whole primary case off the side of the bike to get to this? Looks like there wouldn't be any other way...
Hope this isn't a massive job, but I don't want to ride the bike and wear that part out further and induce any damage.
Thanks for any help you can provide!
here it is
https://www.hdforums.com/forum/touri...he-tranny.html
1. Take the bolt out of the arm, move the arm to the end of the shaft , clean everything up with brake cleaner and then put the bolt back in with a little locktight and snug it all up. If the teeth on the shifter arm are still good, this will work. If the shift arm teeth are wasted then..
2. remove the bolt from the arm, take a long chisel and break the arm off the shaft (carefully) and spend some cash to buy and install "the better Lever" it costs a lot but saves you from pulling the primary.
3. Don't buy the better lever and pull the inner and outer primary and replace the shifter shaft with a new one. in all likelihood you will need to replace the seals in the inner and outer primary and most likely will need to put in the upgraded front pulley with new outer seal and quad seal.
On my 89 when I had to do that job, I also had a bunch of seal leaks so I pulled the primary , replaced all the seals and gaskets, upgraded the front pulley and replaced the shifter shaft and used an upgraded bolt with locktite. Stayed tight and leak free for 7 years till I sold it. If you get all the parts ahead of time and have the tool for the clutch and the manual, you can do the job in a day and be back up and running.
