fork oil leaking--
Old Nov 18, 2012 | 04:55 PM
lkr0's Avatar
lkr0
Default fork oil leaking--
06 SG 23k miles have fork oil leaking from the screw on the fork -- saw oil on the rim about a dime size -- checked the forks no oil on them -- I made an attempt to tighten the screw but it seems pretty tight -- suggestions
Old Nov 18, 2012 | 05:03 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Stock forks or have recent lower chrome legs been installed?
Old Nov 18, 2012 | 05:35 PM
dawg's Avatar
dawg
Since it has 23k miles on it I'm guessing the oil hasn't been changed. Albeit HD says to change at 50k, it should be changed more like 25k so I suggest changing the oil and use new drain screws/washers if stock legs. If chrome or powder coat and it has chrome screws then I'd just get new crush washers.
Old Nov 19, 2012 | 02:55 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
I don't understand why manufacturers refuse to use standard NPT 1/16 plugs on the forks; even a short stainless steel (brake) bleeder screw would be welcome.
Old Nov 19, 2012 | 04:19 AM
jjnoble's Avatar
jjnoble
Those screws are in there very tight, you need a decent tool to break them loose or you will strip the heads. Maybe they are just not tight enough. But sounds like a bad crush washer. Do what Dog says, if they are tight, then at the very least you will need to replace the washers, a screw might be damaged too, so replace those also. You will lose your oil when you do that so just change you oil and get new hardware.
Old Nov 19, 2012 | 07:03 AM
lkr0's Avatar
lkr0
chrome lowers changed out at 5k miles
thank you all
Old Nov 19, 2012 | 07:10 AM
1flhtk4me's Avatar
1flhtk4me
I think there would be more problems using those.
Old Nov 19, 2012 | 08:57 AM
Expat1's Avatar
Expat1
In case of a leak, fork screws with a 'Phillips' head#2 on a coarse thread have no Metric equivalent; only chewing gum works like a charm.
Old Nov 19, 2012 | 10:37 AM
larsfum's Avatar
larsfum
You can try tightening it with an impact driver:
http://www.sears.com/craftsman-impac...p-00947641000P
You'll need one to get them off if they are tight.
Mike Kirk
Nov 26, 2016 01:49 AM
kjkustoms
Jan 23, 2009 06:30 AM
earthdog
Sep 21, 2007 02:44 PM
tuff
Jul 25, 2007 10:03 AM
whiplush
Oil Archive (no new posts)
Apr 12, 2005 07:46 PM
