5" speedo have the same connection as 4"
Old Dec 10, 2012 | 04:36 PM
ReidRik_Von's Avatar
ReidRik_Von
Default 5" speedo have the same connection as 4"
Hi All,
I have a thread going here about trying to move the speedo next to the tach on my 09 FLHP. I am still trying to work through the details and I need to know if the wiring connection for my stock 5" RK speedo is the same as the 4" speedo used on other fairing touring models. I have the manual however it doesn't show photos of the actual connection. Does anyone know if they are the same? I am hoping that this would be a plug and play swap...
Many thanks!
Old Dec 13, 2012 | 09:11 PM
ReidRik_Von
Bump.
Old Dec 14, 2012 | 06:19 AM
Scrmnvtwins's Avatar
Scrmnvtwins
Bump2 Interested in the answer.
IMO and just a thought as I don't know for sure, the '09 tachs and speedo are all driven by electronics not cables so it seems to me you could remove a 5" dash and speedo and replace with say a Dyna dual 4' tach and speedo dash then splice & wire the plugs. The 5"should have indicator lights that will not necessarily be in the 4' speedo alone so a wiring harnes from the 5' and 4' applicatioon would be needed.
Old Dec 29, 2012 | 02:20 AM
ReidRik_Von
Default 5" speedo have the same connection as 4"??
So I had some time today and combed through the 09 Touring Manual and the 09 FLHP/FLHPT supplement and I think this will work.
These are the manual pages for:
FLHP
FLHR
FLHT
FLHTP
Based on these diagrams ALL appear to have this pin arrangement in a 12-place Packard connection:
1 Ignition
2 Serial data
3 NC
4 NC
5 Battery
6 Accessory
7 Ground
8 Trip Switch
9 Fuel Level
10 Cruise Enable
11 Trip Switch
12 Cruise Active
So it looks like one could replace a 5" RK speedo with a 4" model from a fairing touring model and use the existing connection assuming that the wire harness is lengthened such that it will reach to the 2-up gauge cluster I'd like to use. Now I just need to find a 4" speedo that matches my current tach with the chrome ring:
I did some searching on Ronnies and the speedos used in the FLHT/FLHTP models have a black trim ring (PN 67349-08). I poked around and it looks like this 4" speedo (PN 67436-08) has the right face and trim ring however I am not sure if this will work in a touring model. I have a Q into the folks at NewcastleHD however they are off until after the New Year. Any know if 67436-08 will work in an 09 touring bike or if there is another 4" speedo PN with the look of my Tach? The ebay links I found have 67436-08 listed as Sportster speedo and I could not find this PN on H-D.com to see if it would be compatible with other HD models.
THx
Old Jun 9, 2014 | 12:22 AM
ReidRik_Von
Originally Posted by ReidRik_Von
...I need to know if the wiring connection for my stock 5" RK speedo is the same as the 4" speedo used on other fairing touring models.,,,
The answer in the case of my 09 FLHP is yes. I made the swap and it is detailed here.
ReidRik_Von
Jun 1, 2021 09:18 PM
turdlefxst
Mar 20, 2016 01:07 PM
Michael Ficken
Sep 22, 2014 03:39 PM
electricstart
Aug 17, 2009 02:09 PM
razehog
Jun 5, 2007 11:04 PM
