Need opinions
Old Dec 28, 2012 | 08:11 PM
tom071200c's Avatar
tom071200c
Default Need opinions
I just got done installing new inner/ outer cam bearings, tensioners, and lifters into my bike. I tore the rocker boxes down so i could use the stock push rods. I cranked the motor with the plugs out until the oil pressure light went out. Put plugs in and fired it up. Runs great and the pressure light stays out but the valve noise is very noticeable. I let it run for about a minute then shut it off and looked for leaks. Restarted and let run for about another minute and the valve noise persists. Does it take a while for the oil to get to the roxer boxes? I left the new lifters in oil over night then installed them but the bike sat another day before i started it. Im hopin the lifters need primed and havent got oil up the pushrods yet. Should i just let it run? Runs great, revs great,no noises besides a tapping/ knocking from the lifter /pushrod /rocker area.
Old Dec 28, 2012 | 08:33 PM
bklynbob's Avatar
bklynbob
If the motor is really cold,it could take up to 10 minutes for them to pump up.
Old Dec 29, 2012 | 05:27 AM
tom071200c's Avatar
tom071200c
Thanks! I spent a lot of time last night searching the internet and it sounds like the lifters are the problem and that its not to uncommon of an issue. Im gonna let it idle for a while and see if they pump up. Hope i dont have to tear apart again!
Old Dec 29, 2012 | 05:36 AM
tbone108's Avatar
tbone108
Hello there
have you seen the vid clip from Revolution Performance on adjusting push rods.
All the best
tbone
Old Dec 29, 2012 | 05:44 AM
Jswerve's Avatar
Jswerve
Originally Posted by tbone108
Hello there
All the best
tbone
Aren't you going to link it to him?
Old Dec 29, 2012 | 05:57 AM
stevefxdi's Avatar
stevefxdi
my bike took a little while for the noise to go away after doing the same job you did, he dont need to watch a video for adjustable pushrods, he said in his post he use the stock one.
Old Dec 29, 2012 | 08:09 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Dont worry. Let it warm up idling, don't rev it. A warm engine is a different beast than one that is cold, especially after any type of rebuild where oil needs to be but has not had time to get their yet. (if that makes sense)
Old Dec 29, 2012 | 02:58 PM
tom071200c's Avatar
tom071200c
Thanks everyone. Good news! I let it idle for about 10 mins and everything is good. I could actually tell a difference right at startup on the noise level. Then as is it got warm it sounded much better. back to the normal "sewing machine" levels. Started it back up a couple times as I cleaned up the garage and it seems perfect. Actually starts a lil better than before unless its just my imagination.
Great feeling to know that its back together and everything is ok. Great satisfaction from working on your own scoot!
Now back to hibernation mode on the lift and Battery Tender. Waiting on my HD Premium Indoor cover to come in that the wife got me for Christmas.
Old Dec 29, 2012 | 03:15 PM
HDV-GLIDE's Avatar
HDV-GLIDE
For future reference, lifters cannot just suck oil inside themselves by just submerging them in oil.
You have to use some plastic tubing or heater hose and a shop vac to suck (pre-charge) the oil into the lifter.
Not sure if it's necessary to pre-charge them but I did it that way for piece of mind.
Old Dec 29, 2012 | 03:45 PM
tom071200c's Avatar
tom071200c
Thanks. I was just going off the recommendation of the Indy that installed the outer cam bearings for me. I also used that method when I rebuilt my small block Chevy on the recommendation of my dad. Must be old school wisdom? The Chevy was primed on the stand though with a drill driving the oil pump until oil flowed from all the pushrods.
I was going to just reuse the stock lifters as the bike only has 21,500 miles on it. But the indy showed me a mark on the intake lobe of the front cylinder that indicated the lifter roller had dragged on it a few times. So I just changed all four.
fugawi
Aug 21, 2017 02:54 PM
Mitch Mitchell
Engine Mechanical Topics
Oct 21, 2015 10:02 AM
HD_Matt
Mar 21, 2015 09:37 AM
MacKo2000
Apr 27, 2014 10:54 AM
mjunk1
EVO
Jul 5, 2011 03:54 PM
