Exhaust for stage 1
Old Jan 9, 2013 | 05:33 PM
Kingman81008's Avatar
Kingman81008
Default Exhaust for stage 1
Maybe a dumb question.
Do I need to change the entire exhaust on my road king to do the stage 1 or can I get free blowing slip ons.
Old Jan 9, 2013 | 05:46 PM
ninetyzero's Avatar
ninetyzero
Stage 1 consists of higher flowing exhaust, higher flowing air cleaner, and a tuner of some sort if fuel injected
Old Jan 9, 2013 | 05:51 PM
Uncle Paul's Avatar
Uncle Paul
if you have a cat in the exhaust, that should be addressed.
Old Jan 9, 2013 | 05:57 PM
Roger That's Avatar
Roger That
Old Jan 9, 2013 | 06:03 PM
mkguitar's Avatar
mkguitar
you could post year and model when you have a question as there may be different answers depending on what you have.
2009 CA bikes have cats ( 49 State bikes do not- although CA spec bikes may be sold outside of CA.- the VIN will tell)
2010 + all touring have cats in the headers...but in a different location than the above. Also the o2 sensor type/size and location changed into 2010 and up.
the cat is a restriction to flow and sound, so many remove the cat ( search for the tutorial) or buy a new header pipe system
you can just replace the mufflers...however some riders report good results with the stock 2010+ muffler once the cat is removed.
doing just that will get a louder exhaust note.
for performance gains you will need a hi flow intake- i like the Ness Big Sucker for about $115
If you do both of these you will likely need to compensate tuning- a ball of wax with answers from $120 ( nightrider.com Xieds, which I use) to a few hundred bucks to a replacement ECM. Lots to read up.
mike
Old Jan 9, 2013 | 06:32 PM
gunnerchevy's Avatar
gunnerchevy
Ive always change entire exhaust.
Old Jan 9, 2013 | 08:28 PM
0ldhippie's Avatar
0ldhippie
You do not NEED to change the header but there are some out there that perform better than stock. If you will feel the improvement with only stage 1 depends how much feeling ya have your ***. BTW I have seen no hard evidence the cat restricts flow/power on a stage 1 setup.
James1979
Exhaust System Topics
May 23, 2023 05:46 AM
user 78082023840
Milwaukee Eight (M8)
Mar 6, 2019 06:05 AM
kevjo
Oct 31, 2012 09:40 PM
KWC6
Dec 20, 2011 06:55 PM
Spanky09FatBoy
May 9, 2010 08:06 PM
