garmin
Old Feb 1, 2013 | 09:54 AM
CHILLLS's Avatar
CHILLLS
Originally Posted by christophgage
The Zumo's do not support A2DP. It just uses Bluetooth to send the directions to a Bluetooth headset.
good idea, thanks
Originally Posted by tonsa
I have the Zumo 665 with Bluetooth and Sirius. I got the 3 month promo for Sirius but didn't go for the monthly. I just use the sd card works great. I have the iphone 5 and hooked it up with Zumo 665 using the Bluetooth, works great with the Scala.
can you listen to music from your IP5 through bluetooth & through the 665 onto your stereo?
Old Feb 1, 2013 | 04:06 PM
tonsa's Avatar
tonsa
Originally Posted by CHILLLS
good idea, thanks
Yeah as long as the aux port is connected to the Zumo
Old Feb 1, 2013 | 04:39 PM
sgdiesel's Avatar
sgdiesel
Spot on, no a2dp means no decent audio
According to this Garmin page the 660 supports a2dp, but....I am not sure whether it supports streaming in both directions - ie transmit or receive??
https://buy.garmin.com/shop/shop.do?pID=15000
Old Feb 1, 2013 | 08:29 PM
hd_rolling's Avatar
hd_rolling
I just went to check my 660. I can connect my Iphone 4s to the bluetooth phone and make and receive call but no music. There is an audio bluetooth but it will not connect to my Iphone.
Old Feb 1, 2013 | 09:51 PM
CGLTD's Avatar
CGLTD
Sorry wasn't specific enough. It can stream music (A2DP) from garmin to a Bluetooth headset but doesn't receive it from a phone for example.
Old Feb 1, 2013 | 10:28 PM
TNB's Avatar
TNB
Thanks.
Old Apr 1, 2013 | 06:44 PM
patches141's Avatar
patches141
Stage II
Has anyone been able to talk on the phone through the Zumo with the Harley seven pin headset on an Ultra Limited ? I have a 665. it pairs up fine with my phone but when making a call the sound comes through the headset but the microphone on the headset doesn't pick up my voice. I've discussed it with Harley and Garmin for countless hours and no one can figure out how to make this happen. It seems there is only a connection for the audio out but not for the mic in between the GPS dash mount and the Harley NIM module.
Old Apr 1, 2013 | 07:25 PM
rmc115's Avatar
rmc115
It uses the built in mic in the 665, I have stopped before when a call came in and with the bike off in a quiet spot it worked. There is a wire in the mount for external mic, worth trying. Mike
Old Apr 1, 2013 | 08:48 PM
emsdoc's Avatar
emsdoc
You have to get a BOMM and wire it into the mic circut inside the fairing. I have this and can make and receive calls while riding. I don't remember the web site that I got it from but you can search for it on the forum.
Old Apr 1, 2013 | 08:57 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Yep, I have one too and the Bomm is what you have to have to get transmit audio for a phone conversation.
http://www.hdbomm.com/index.html
kryingame
Audio Systems
May 8, 2014 06:58 PM
hotshot
Jul 29, 2009 06:06 PM
elwoodto
Apr 1, 2009 05:05 AM
Chilhowee
Sep 14, 2007 05:47 PM
daboys53119
Apr 12, 2006 10:32 AM
