Headlight removal question
Old Jan 26, 2013 | 07:05 PM
philb252's Avatar
philb252
Default Headlight removal question
Hello all, I am cleaning the hazy buildup out of my 2007 Electra Glide front lights. Thanks to instructions posted previously on this forum I knew exactly how to do that with the passing lamps. My question is, will the headlight remove from the front or do I have to take off the batwing and take it out from behind?
Old Jan 26, 2013 | 07:13 PM
Lowcountry Joe's Avatar
Lowcountry Joe
You don't have to remove the batwing. You can get the light out from the front. Once you remove the three (I think) screws that hold it to the headlight adjuster frame, it will slide out a little, enough for you to remove the plug from the rear of the bulb. Then once out, you can remove the bulb and start cleaning the foggy film from the inside of that lens. Just take your time.
Chiledog
Mar 14, 2014 09:21 AM
tidbit1
Mar 20, 2012 10:41 PM
cowhauler
Jan 29, 2011 09:21 AM
Joe What
Oct 10, 2010 03:24 PM
alissa74
Nov 7, 2007 08:43 AM
