Same oil in Tranny, Primary and Engine?
Old Jan 29, 2013 | 07:51 PM
jmn1960's Avatar
jmn1960
2005 ultra,,,40k on the clock
mobile syth 20/50--eng
mobile syth 75/140 trans
straight ATF prim,,
never had a problem
Old Jan 29, 2013 | 08:19 PM
WI Bob's Avatar
WI Bob
Originally Posted by the warden
Ditto. While some may think that running a good synthetic in the primary is a waste, I think it contributes to longer life of the chain and chain tensioner pad. If you are mechanically inclined this is no big deal to replace, but if you are not, the extra cost for synthetic will soon offset the labor cost to replace the tensioner pad more frequently.
It will also contribute to a slipping clutch once torque gets around 110.
Old Jan 29, 2013 | 08:33 PM
NECaveman's Avatar
NECaveman
Engine: Mobile 1 V-Twin 20W50; Primary and Transmission: HD Formula+. I ran Syn3 in all three holes on my 2009 SG since the first oil change up to last fall with 14K miles. Changed oil brands attempting to reduce engine and transmission noise. No real noticeable change with the engine, but the transmission is definitely less noisy and shifts easier with HD Formula+.
Last edited by NECaveman; Jan 29, 2013 at 08:40 PM. Reason: Grammar and additonal info.
Old Jan 30, 2013 | 04:03 PM
corliss@bakerdrivetrain.com's Avatar
Do not run motor oil in your trans. Reason; motor oil has very little zinc or phosphorous content these are the 2 components that you need for gear protection. Motor oils also have detergents to clean out the burnt deposits. Nothing burns in the transmission it does not need detergents.
Old Jan 30, 2013 | 04:21 PM
Sagido's Avatar
Sagido
I used Redline in my last bikes transmission, loved it, noticably quieter. Will be switching over when I get my 1k mile service done. I have no issues with SYN3 for the motor, and have yet to make up my mind on the primary. Used Redline in the last primary with no issues. But leaning towards Harley Formula +
Question: Why does Harley Davidson reccomend diffrent change intervals than most dealers provide? Motor: 1K, 5K, 10k, 15k, 20K etc..... Primary: 1k, 10K, 20k, 30K etc..... Transmision: 1K, 20K, 40K, 60K etc.....
I have never drained my transmission without thinking it was a waste since the fluid look like I had just poured it in the fill hole.
Curious to see responses???
Old Jan 30, 2013 | 04:35 PM
cezariomaia's Avatar
cezariomaia
Motul 7100 20W50 in motor.
Motul Motyl Gear 75W90 in trans.
Motul Transoil 10W30 in primary
Old Jan 30, 2013 | 04:57 PM
Mr HOG's Avatar
Mr HOG
Originally Posted by kramercarpet
He said I can run the same synthetic 20w-50 in all three.. Ups or Downs?
The only problem i have with this statement is what to use in the transmission. IMO, the tranny needs gear oil and Syn 20W50 is not gear oil. As many others, I run Redline Heavy Shockproof oil in my transmissions.
Old Jan 30, 2013 | 05:23 PM
5TIME's Avatar
5TIME
For all Redline users: I am planning to move to Mobil 1 20w-50 in my engine, Redline primary, and Redline V-Twin Transmission fluid with shockproof. It looks like they indicate that it is the same thing as the old shockproof. Is it? I can't find just "shockproof" gear oil. I was going to buy the Redline products at Cycle Gear. Any better suggestions?
Old Jan 30, 2013 | 05:28 PM
honestbob's Avatar
honestbob
NO! anyone says anything else is stupid!!!
Old Jan 30, 2013 | 05:45 PM
RK Fan's Avatar
RK Fan
Default MY Local Dealer recomends...
HD Formula Plus in the Primary
SYN 3 in the Engine
Bel Ray in the transmission
