Upgrade my System?
Old Feb 5, 2013 | 07:39 PM
harley.farmer's Avatar
harley.farmer
Subscribed...
Old Feb 5, 2013 | 07:55 PM
exwrestler's Avatar
exwrestler
Like I said I want to do this setup once(hopefully). I'm really excited to do this install. Usually when I get excited I get impatient so I'm sorry for asking so many questions but every input helps. Thank you and keep the input coming. I want to buy something soon. Too bad I can't try before I buy
Old Feb 5, 2013 | 08:01 PM
exwrestler's Avatar
exwrestler
By the way what is the RMS of the Boom Audio Saddlebag Speakers?
Old Feb 5, 2013 | 08:07 PM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by exwrestler
I'm thinking of stock head unit. Boom audio fronts and rears in bag lid. Powered by a hogtunes amp. But it feels as though I'm spending a lot for a little. What about the rockford 300x2 or 300x4 can I run this setup. I'm so confused. Especially with 2 ohm 4 ohm, 2 channel 4 channel. Etc.
Stay away from the PBR300x4...
Old Feb 5, 2013 | 08:11 PM
CGP93's Avatar
CGP93
From: Orig Surfers Paradise Australia, then Riyadh Saudi Arabia, Tokyo, Toronto, now So Cal
So can I run a rockford 300x2 for the fronts which I will go with j&m fronts and another rockford 300x2 for rear bags. I can get a set of boom audio lids and speakers for cheap from a friend. I think he want $250 for the lids and speakers. Or should I run a hogtunes amp? Or run fronts off head unit and rears with a rockford 300x2 he also has a hogtunes 40.4 I think that's the model? It's a 4 channel hogtunes amp
IMO i would stay away from the hogtunes, especially the 40.4 amp - just not enough power. HT's is a good company with excellent customer service and provides a good upgrade from stock that is P&P - this satisfies a vast majority of owners, and fair play to them... I just know you'll be after more performance...
Yes - you can run the PBR 300x2's, one for the J&M's up front and another for the bag lids, this would be gr8.
However, if you're dead set on a 4 speaker set up, consider the Sound Stream Nano 4 channel amp, its very reasonably priced, and gives you 4 channels at 125w per channel at 2 ohm load. This amp will fit in your fairing, and you'll save the extra coin from not buying the 2nd PBR 300x2 and furthermore save on space taken up in siting this 2nd amp, just food for thought - I personally would go for the SS if I wanted a 4 speaker set up.
If you choose the PBR 300x2 below is my set up with the J&M Rokkers:
*Freq set at 80Hz
*Gain set at 4
*Cross over set at HP (High Pass) - not AP (All Pass)!! - AP has been reported to over heat the amp and possibly cause failure at some point.
Another note on the PBR 300x2 install is to ground it to the negative battery terminal!! NOT the ground at the forks - other forum members did this and have blown amps.
The PBR 300x2 is loud, clear and crisp with more than satisfactory base response (remember its a Harley, not a home theater!) I have suffered from no clipping and no heat issues running the PBR 300x2 in this configuration and set up.
The J&M Rokker XTC's do a great job with this little, powerful amp.
Others here may chime in on the heat from the PBR line of Rockford Fosgates, I can only speak from my experience and the 300x2 with my set up is fine, no heat,no clipping and no distortion until about 4/5th of HK head unit volume.... but well before that volume your ears are bleeding, your eyes are squinting and your Mrs will think you've had a stroke!
I would agree that the PBR 300x4 DOES GET TOO HOT - I wouldn't buy this amp, I'd choose the Sound Stream Nano over the pbr 300X4
Check Ultranutz's posts on the SS - he is an AMAZING source of info, and i think he agrees that the PBR 300x2 is a gr8 amp for a 2 speaker set up, but the SS is the way to go for a solid cool running 4 channel amp at a gr8 price.
Good luck buddy, let us know what you decided on!
Old Feb 5, 2013 | 08:22 PM
exwrestler's Avatar
exwrestler
I didn't know about the ss nano amp thanks! So here is what I'm thinking. Harmon Kardon head unit Soundstream nano amp. J&M fronts 2ohm. Boom Audio rear 2ohm. Stay away from hogtunes 40.4 and Rockford 300x4. How's that setup sound. Ohh and a line converter. Should still be able to use my stock handlebar radio controls.
Old Feb 5, 2013 | 08:23 PM
exwrestler's Avatar
exwrestler
Or 2 Rockford 300x2 amps?
Old Feb 5, 2013 | 08:35 PM
CGP93's Avatar
CGP93
Either of those 2 set ups will put a smile on your face! - HAVE AT IT!!!
Just take your time with the install, do your install research here on the forums, oh and dont forget to have 12 or so of your "best friends" on ice as installation fluid to stay hydrated during the process.. (this is PARAMOUNT!!)
PM me if you need any tips installing - happy to help you out mate.
Old Feb 5, 2013 | 08:41 PM
monumaker's Avatar
monumaker
I have read and researched for weeks on this... I ended up with Sony deck, arc 4 ch amp, focal 6.5 up front and focal 6x9's in bag lids. All provided by dragonfly. Call Kevin he will hook you up.
If I had a 1000 budget I would do arc 2 ch and focal 6.5's up front.
IMHO... Buy once, cry once. Go high end. Don't waist ur time on the cheap ****.
Old Feb 5, 2013 | 09:05 PM
CGP93's Avatar
CGP93
Focal are fantastic speakers!!! if i had the budget - yeah that would be the weapon of choice! good one!
