Speedometer sensor??
Old Feb 4, 2013 | 09:53 PM
lip's Avatar
lip
Default Speedometer sensor??
I have an 01 electra glide. speedo needle flopped around for a day or two then quit. cleaned off the sensor it's still not working. should the next logical step be to buy a new sensor? Is it the sensor that fails most of the time? or the speedo itself? hate to spend $60 for the sensor and find that is not the problem.
Old Feb 5, 2013 | 06:09 AM
qmann's Avatar
qmann
Common for sensor to get dirty, metal shavings, etc. I have a 2000 EG, mine did the same thing several years ago - recommend to replace not to clean, especially for $60.00. Good luck! If I remember right, you might have to remove starter for access.
Old Feb 5, 2013 | 08:17 AM
Harley58's Avatar
Harley58
Speedometer sensor needs replaced. Mine did the same thing. I was able to replace it with out removing the starter.
Old Feb 5, 2013 | 09:35 AM
Hotrodz_n_Harleyz's Avatar
Hotrodz_n_Harleyz
The big give away if it's the sensor is that the auto cancel on your turn signals quits working as well. Part of what the sensor does is tell your turn signals to shut off once the tranny starts winding up. So, if your auto cancel stopped working along with your speedo, it's no doubt the sensor. The sensor itsellf is a breeze to change, it's getting the damn wire routed like it should be that's a bit of a pain in the ***.
Old Feb 5, 2013 | 04:07 PM
BCW567's Avatar
BCW567
I learn something everyday reading this forum. Thanks Hotrodz
cc_Penguin
Jun 11, 2021 01:10 PM
Stiggy
Electrical/Lighting/Alarm
Oct 1, 2016 09:40 PM
shakrr
Mar 31, 2013 07:22 PM
hammon
Jun 9, 2008 06:44 PM
FreddyP
Jul 7, 2006 11:42 AM
