Fork Removal
Old Feb 10, 2013 | 02:39 PM
jrat69's Avatar
jrat69
Default Fork Removal
I ordered my Monotubes today, how high does the bike need to be raised to remove the fork tubes? I have a table and a jack just trying to plan ahead. I don't like to raise it any higher than it need to be.
Old Feb 10, 2013 | 02:41 PM
rickdavis's Avatar
rickdavis
I'd say if it's high enough to remove the front tire, once its off, you should have room to slide them out of the triple trees.
Old Feb 10, 2013 | 02:42 PM
pscyclepath's Avatar
pscyclepath
If its high enough to get the wheel of it is high enough to remove tubes.
Old Feb 10, 2013 | 03:46 PM
mfortkamp's Avatar
mfortkamp
I did mine on the lowest setting on my black and red craftsman jack
Old Feb 10, 2013 | 04:08 PM
sanman4ever's Avatar
sanman4ever
I've read you should chock up the rear tire too. Because the bike can become out of balance on the jack once you remove the front wheel?
Old Feb 10, 2013 | 05:41 PM
MikeTD3's Avatar
MikeTD3
Yes, the rear wheel should be chocked as the bike will shift it's weight to the rear when you remove the front wheel.
Old Feb 10, 2013 | 06:23 PM
RANGER73's Avatar
RANGER73
Strap it to the jack and raise it about a foot.
Old Feb 10, 2013 | 06:33 PM
BrownSanta's Avatar
BrownSanta
Nice write up on fork removal
https://www.hdforums.com/forum/touri...-write-up.html
Old Feb 10, 2013 | 09:09 PM
1BADSG's Avatar
1BADSG
Just took my forks off a few weeks ago to get powder coated. Strap bike to jack as stated and lift high enough to remove wheel. Good luck!
Old Feb 11, 2013 | 11:08 AM
Joe12RK's Avatar
Joe12RK
I did my forks with a jack made of two 2x8's and a length of pipe. it lifted the frame so the front wheel was off the ground and the back stayed put. very stable and easy to make. joe
