Oil Drain Device
Old Feb 13, 2013 | 05:06 AM
  #31
kdodd's Avatar
kdodd
I like the idea of punching a hole in the filter and letting it drain. I will try that next time.
Old Feb 13, 2013 | 06:33 AM
  #32
btsom's Avatar
btsom
I am also a user of the aluminum foil, the heavy duty is a bit more stiff so not so prone to crinkle up. Even so, still no such thing as a dry or clean filter change on the 96. Ultimately went to the Sta-bo front engine mount as the urethane is supposed to be impervious to oil. So far, so good.
If the filter had left hand threads, rotating it would sling the oil onto any tray rather than away from it as happens now.
Old Feb 13, 2013 | 08:53 AM
  #33
Watchfuliz's Avatar
Watchfuliz
The hole punch method only helps reduce the spill, it doesn't stop it as a lot of oil is still in the filter when it comes off. I punch two holes, both in the very end of the filter. One at the very bottom edge and one at the top. I put my plastic tray I made under the filter before I punch the holes to guide the oil into the drip pan. Patience is the key here, it takes awhile to drain so give it time. Then push the blue paper shop towels under the filter with a long screwdriver to help catch the oil from the spin off.
Like I said, not all the oil is going to be caught so you will still need to do some cleaning.
smokingjoe
Milwaukee Eight (M8)
37
Jul 24, 2017 10:44 AM
deadman77
Oct 18, 2015 06:45 AM
Timpechos
Jul 5, 2013 10:14 AM
LucyOnBlack
Oct 30, 2011 10:39 AM
Demkay
Oil Archive (no new posts)
Mar 15, 2008 03:38 PM
