Does anyone know is a rear wheel, with pulling and break disk off a Fatboy would fit an Electra Glide? The one I'm looking at is 16" which is the same size. It's is not the solid wheel. The Tire size is 140/90/16
Any help would be appreciated!
We need to know what year your bike is and also the year of the FB wheel, as there are several things that may get in the way. Tapered bearing wheels won't fit, as the touring bikes use a different rotor and caliper. Early ball-race wheels can be modified to fit. The softail wheels come with 3/4" bearings that will take the 1" touring bearings, but need to be machined to take the larger diameter bearing spacer. I'll stop there!
As it's a custom wheel it should fit without machining the hub. You will need a bearing kit, which Harley sells for all wheels and comes complete with bearing spacer, valve stem, etc. Harley wheels that fit many models can be fitted with 3/4", 1", or 25mm bearing kits, to suit. You can confirm that by visiting Harley's website, where that wheel is still listed, complete with instructions:
