CRUISE INSTALL?
Old Feb 11, 2007 | 01:00 AM
BUIZILLA's Avatar
BUIZILLA
Default CRUISE INSTALL?
my dealer wants $684 installed w/tax
is this a good deal?? or is it an easy install if I buy the kit and do it myself?? I can get the kit for $272 plus shipping, saving $400 appeals to me....
thanx, Jim
Old Feb 11, 2007 | 01:03 AM
bay13's Avatar
bay13
Default RE: CRUISE INSTALL?
I haven't done it to mine, (yet), however I've heard enough talk about it on the forums here that when I decide to get the HD cruise control I will be installing it myself. Lots of help and experience here.
Old Feb 11, 2007 | 01:16 AM
tgaetto's Avatar
tgaetto
Where can you get it for the 272+ I'd like to get the unit @$%& the dealer 400 way to much......
ORIGINAL: BUIZILLA
thanx, Jim
Old Feb 11, 2007 | 01:18 AM
hd2007's Avatar
hd2007
Bad deal , order it and do it yourself , we can walk you through it when you get it . Save the cash and buy yourself some chrome.
Old Feb 11, 2007 | 01:31 AM
BUIZILLA's Avatar
BUIZILLA
I am pretty mechanically inclined.... then I can put the $400 towards some exhaust and PCIII stuff...
Old Feb 11, 2007 | 01:33 AM
bay13's Avatar
bay13
I know Benjys in WV at 304523-1340 sells at 20% off suggested retail. Call and ask to talk to Jenni.
$339.95 retail minus the 20% is $271.96. It can be found on page 483 of the 2007 accessories catalog.
Old Feb 11, 2007 | 01:40 AM
StreetGlider56's Avatar
StreetGlider56
ORIGINAL: BUIZILLA
thanx, Jim
The install isn't that bad, I want to know if the cruse switch is included in the packaging for the 272? I am going to install it on my SG real soon...
and 400 bucks is quite high for the install.. I think this should be a standard feature on a SG...I really got spoiled to it on my 06 Ultra...
[IMG]local://upfiles/11910/55A9EA2718634F9A8C388297A50BE82A.jpg[/IMG]
Old Feb 11, 2007 | 01:49 AM
bay13's Avatar
bay13
The cruise kit comes with the switches you need.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Feb 11, 2007 | 02:28 AM
iclick's Avatar
iclick
ORIGINAL: BUIZILLA
You can do it yourself, but you'll need patience and a service manual. I've been tinkering on MC's and cars for 45 years and it is not the easiest mod I've made to a vehicle. Read the instructions, then the Cruise Control section of the manual, and then do a search of this forum for "cruise control" and read everything you find. Then you have an idea of whether or not you can handle it. You'll read about our problems and hopefully they won't become yours.
Some caveats:
1. You'll need to install three pin connectors for the switch into an existing harness on the bike, a process not described well in the instructions. Installing these is not self-explanatory, and you'll need to consult the electrical section of the manual. So make sure ahead of time you understand where they go in the harness and how to install them.
That will save lots of time and frustration.
2. The final step of the ordeal is the initialization procedure, which is also not in the instructions but clearly described in the CC section of the manual.
3. The new switch housing and original brake bracket on my bike did not want to play well together, and that took about 30 min. to reconcile. Do that step carefully by looking at how they fit together before removal, and even though I've done that job several times in the past it was a PITA this time around.
Once you have a grip on these three things the rest is fairly straightforward, and you should be able to install it in 2-3 hours.
Old Feb 11, 2007 | 07:19 AM
IndyRider's Avatar
IndyRider
Jim, I installed mine on my 2006 Road King a few months ago. It is not rocket science but it does take some time. Follow the advise here and take your time. The help of a friend will make the job a little easier.
Where I had the most problems was getting the tiny C-clip on the FI throttle cable. Took several tries and a trip to the hardware to buy a replacement clip after I lost it in the process.
Also take you time in putting the new switches back on. Be sure to get the cables into the groves and not pinched.
Good luck and spend the saved $400 on something else.
