Hogtunes Amp ?
Old Feb 11, 2007 | 01:36 AM
Badbagger's Avatar
Badbagger
Default Hogtunes Amp ?
Just curious if I can a Hogtunes or other amp in addition to the Hogtunes speakers FRONT only. Not going to add any rears right now on my tour pak. Perhaps next season or at the mid point of this upcoming season. Planning to install the Hogtunes speakers in a few weeks or so.
Thanks
Boogey Man
Old Feb 11, 2007 | 01:38 AM
RANDIT's Avatar
RANDIT
Default RE: Hogtunes Amp ?
from what i have read on the forum yes. pez will sell the amp for use with the front speakers. no need to have the rear speakers
Old Feb 11, 2007 | 02:39 AM
iclick's Avatar
iclick
ORIGINAL: a.boogeyman
I've been toying with this idea too, but before I pay $200 I want to make sure there is a major improvement in the sound. If not, I'll struggle with the status quo. Based on what little has been said here I'm not convinced of it, but I'm still open minded.
Old Feb 11, 2007 | 08:51 AM
Badbagger's Avatar
Badbagger
I am in the same boat. I know the Hogtunes swap for stock alone is a major improvement. I'd like to know how much the sound improves with the amp.
Old Feb 11, 2007 | 09:07 AM
JeffSG's Avatar
JeffSG
I feel that the OEM speakers do a good job. I also plan to get the Hogtunes and if they improve performance as much as everyone says, how much better can an amp enhance performance?Will it just make itlouder? If that is the case, I will not need it.
Many thanks and ride safe,
Old Feb 11, 2007 | 03:22 PM
jj9150's Avatar
jj9150
i do not have the hogtunes amp, but in my cars i have 2 to 3 amps in each, what the amps really helps with is, making better volume with less "push" from the head unit, basically the stereo head unit does not have to work as hard to get the same amount of volume/sound, much distortion comes from the stereo pushing its limits, not from the speakers themselves,also some stereos automatically remove certain tones as the volume level increases, ( i noticed this on one of my factory radios once, the led volume "bars" would literally drop half the bass once you got to mid point one the volume control,take it down one bar, bass came back).
basically the lower volume the head unit is puting out the cleaner the sound will be coming from it. stereos with internal amps have to use power to run speakers, using that power takesaway from supplying power to its internal parts, high end stereos (competition style) dont have internal amps at all, they can only be used with external amps. and mid range stereos have a menu option to turn the internal amp off and run external only.
in theoery , yes an amp just makes your stereo louder, but it makes it louder where it counts, and saves the strain on the head unit.
and nobody ever wants to strain their "head unit"
Old Feb 11, 2007 | 03:33 PM
Harley Rulz's Avatar
Harley Rulz
I have the Hog Tunes amp on My bike with front speakers only.This is the way Pez told Me.The amp powers the front speakers even if you have four speakers.The amp gives you the power your stock unit can't supply with better mid range where you need it.It is a snap to install sense you'll have the fairing off to install the speakers anyway.It takes about 10 more minutes to add the amp.I highly recommend the amp for (I think) another $180.00.
Old Feb 11, 2007 | 08:18 PM
Badbagger's Avatar
Badbagger
Thanks for the info. I will have to try to get up with Pez. I've emailed them several times with absolutely no response. I ended up buying my Hogtunes on ebay for $89. Now I'll need the amp and RG adapter. If I can't get with them again, I'll end up hunting one on ebay or through another supplier.
Old Feb 11, 2007 | 08:27 PM
Harley Rulz
Have you tried to call Pez at His office?Thay have allways answered when I call.
Old Feb 11, 2007 | 09:03 PM
lkr0's Avatar
lkr0
check with yourcar audio shops---they may be able to provide you with an amp (more power than you can use) atless cost, not knocking hogtunes they havegreat products, but there are alternatives. my .02.
I had hogtunes speakers and amp --- but i wanted more sound--went with mb quart speakers in the fairing, kenwood 6x9s in the saddlebags, and a MTX 300 watt 4 channel amp. I got the sound I wanted.
