Ugly ultra 2008 license bracket. Help please!!
Old Feb 27, 2013 | 02:52 PM
Slick03 H-D's Avatar
Slick03 H-D
I opted for the Cycle Visions cv4808c tag mount/tail light combo,,totally hides the oem tail light hole, mounts thru the turn signal bar mounting holes and is led..because I went detachable on my 2013 FLHTK.
Old Feb 28, 2013 | 05:53 AM
kyote's Avatar
kyote
Originally Posted by aso432
>>>>> Has anyone a suggestion on what to do with the old ugly license bracket that holds up the tour pak. <<<<< I was wondering if anyone has a suggestion on what I can do to remove or modify the bracket so it looks better.
Thank you for your input.
I think most of you are missing his question.... ^^^^^^^
Old Feb 28, 2013 | 08:19 AM
Cajun_Arkie's Avatar
Cajun_Arkie
I am putting on a new custom fender on my Ultra classic and the tag will be on the lower fender. Has anyone a suggestion on what to do with the old ugly license bracket that holds up the tour pak. I was wondering if anyone has a suggestion on what I can do to remove or modify the bracket so it looks better.
Are you talking about the bracket that is left when you remove the tourpak on your bike? I think on the pre-2009 Electra Glides that bracket has to be cut off in order to be removed. I have a 2007 UC and did not see a way to simply unbolt it. I think the newer models that bracket is configured differently and is easier to remove. Someone please correct me if I am wrong.
I opted to leave the license bracket on my bike and use the Haulen *** license tag bracket for my license plate.
Old Feb 28, 2013 | 08:54 AM
just plain john's Avatar
just plain john
I like that bracket. J&P have one similar to it.
Old Mar 1, 2013 | 11:50 AM
Slick03 H-D
On my 2013 Limited, the tag mount is one piece to the oem tourpack rack, hence the changing over the taillight/tag mount to the CycleVision unit and then I installed the detachable tourpack rack..
Old Mar 1, 2013 | 09:53 PM
2010FLHTCU's Avatar
2010FLHTCU
Cut mine off with an air cut-off tool, but I know not everyone is willing to do that.
Attached Thumbnails Ugly ultra 2008 license bracket. Help please!!-img_0125-small-2-.jpg
Old Mar 1, 2013 | 10:43 PM
aso432's Avatar
aso432
Default If it is removed, something has to take its place to hold up the tour rack.
If I remove the tag bracket, I will need to put something else in its place. It holds up the tour bracket.
Thanks
for everyones input.
hern50
General Topics/Tech Tips
Apr 30, 2019 09:20 PM
kmcintee
Milwaukee Eight (M8)
Feb 11, 2018 12:15 AM
FUBAR55
Mar 21, 2012 12:58 PM
JS999R
Aug 5, 2011 12:39 AM
Peppa1
Mar 17, 2011 09:28 PM
