Too rich
Old Mar 13, 2013 | 11:52 PM
retarded's Avatar
retarded
Default Too rich
I have a new 2013 streetglide and i got the kit from Jammie at fuel moto.
It came with woods 222 cams, Jackpot header, 4" reinharts, powervision,adjustable pushrods and a airfilter. Installed the parts and reflashed the ecu. Bike fired right up and runs good. Only complaint is the this is a little on the rich side. Should i run the auto tune mode or contactact fuel moto. Thank you
Old Mar 13, 2013 | 11:56 PM
C.H.L.'s Avatar
C.H.L.
I read the title of your post, and was hoping you had too much money, and wanted to give some away...... I am thoroughly disappointed.
Anyway, yeah, try auto tune. If that doesn't dial it in for ya, give them a shout.
Old Mar 14, 2013 | 01:25 AM
ke5rbd's Avatar
ke5rbd
Is it just rich when cold? If that is where it is rich you will have to change it or get FM to do it. Harley and PV use the same warm up enrichment numbers and they are too rich after cams. If too rich after warm up, the auto tune will take care of it.
Old Mar 14, 2013 | 05:35 AM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
^^^ +1, my FM 107build using PC III map from FM is a bit rich when started...after warm up its fine. Best part other than monster TQ is that it doesn't spark knock or pop.
Old Mar 14, 2013 | 06:10 AM
Keithhu's Avatar
Keithhu
How do you know its running rich?
Old Mar 14, 2013 | 08:21 AM
mattbee's Avatar
mattbee
Old Mar 14, 2013 | 08:53 AM
mgmmgm's Avatar
mgmmgm
I have less than 200 miles on my TW222 cams and am using the PV FM map.
Can't say I notice it running anything less than spot on from start up, and after it's warm riding down the road.
I will say, that the cams are great.
Old Mar 14, 2013 | 08:54 AM
retarded's Avatar
retarded
Default too rich
You can smell raw fuel in the cold start mode. Its a bit too fat in the enrichment mode. I have not really ridden it due to crappy weather but i ran it up the driveway and its too rich. Thanks for the replies.
Old Mar 14, 2013 | 09:18 AM
Bo Joe's Avatar
Bo Joe
That's the beauty of the Power Vision, you can hook it up and collect data as you're driving around. What I did was put it in my saddle bag and went for a 5 - 10 mile trip. I actually did one in town and one on the highway so they could see the difference.
Then send your data to them and they can adjust the mapping for you. Then you just reflash the new map back to the ECM. Worked like a charm.
Old Mar 14, 2013 | 09:31 AM
retarded's Avatar
retarded
Thanks Bo Jo good information
