Cigarette Lighter
Old Mar 14, 2013 | 09:25 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
maybe this is why!!
Old Mar 14, 2013 | 09:42 PM
Oldman47's Avatar
Oldman47
Before you use that lighter port for anything, check the polarity. I found mine reversed on both my 2010 Electraglide Ultra and on my 2011 Road Glide Ultra. It blew the fuse on my Garmin because it was reversed and I had to work over the Garmin adapter to get it working again. It turned out to be an internal fuse in the power adapter.
What you should expect to find is the center contact at 12 volts positive compared to the side contact. Anything else will give you problems with any accessory that cares about polarity. That will include things like phones, GPS or similar items. I know that sounds simple but I had 2 bikes in a row wired up backwards.
Old Mar 15, 2013 | 08:28 AM
RPS1981's Avatar
RPS1981
That's exactly what I'm talking about. It's not a myth. Polarity doesn't matter for a cigarette lighter. Phones and GPS units are a little more particular.
Old Mar 15, 2013 | 09:12 AM
Tampakingpin's Avatar
Tampakingpin
can't understand the risk here
Old Mar 15, 2013 | 09:15 AM
Watchfuliz's Avatar
Watchfuliz
Originally Posted by stevevfd
Also make sure whatever plug you use doesn't hit your tank in hard left turns. The plug was put in a bad place.
Yep, that is it in a nutshell. I run my Garmin from mine and have for 4 years and 70,000 miles.
Old Mar 15, 2013 | 09:20 AM
cass's Avatar
cass
maybe they are worried about cords interfering with the control of the scoot. don't want to have a liability suit if the cord gets wrapped around the bars and you have a problem turning.....just a thought.
cass
Old Mar 15, 2013 | 07:00 PM
1st 96 ultra's Avatar
1st 96 ultra
gonna pull my outter fairing off to rewire my acc switch , think I will check the lighter while I am in there
Betteroff
2014-2024 Touring Models
Jun 9, 2014 07:59 AM
broncobob
Mar 11, 2013 10:50 PM
Moneytrap
Mar 26, 2012 08:17 AM
gtrplyr
Jul 7, 2010 08:50 AM
leeinmemphis
Feb 28, 2008 12:53 PM
