need help
Old Mar 14, 2013 | 08:45 PM
outlawDFFD's Avatar
outlawDFFD
Stage II
Default need help
i just go my upper fairing painted. i also added a aftermarket radio to my 08 ultra classic. didnt cut any wires am using the hawgwire kit for it. when running the wires for the amp i used a cable fish rod to run the power and some speaker wires. ( didnt remove the tank ) now that i have everything except the outter shell put back on. when i turn the power on, the gas gauge goes all the way full. and the range on the speedo goes from low to two line. ( -- ) i triple checked that all the plugs are to the right gauges and everything is tight. i have trouble shot this as much as i can. i really dont want to bit the bullet and pay HD 100 bucks a hour. is there anything else i could trouble shoot?
Old Mar 14, 2013 | 09:04 PM
z71_fourwheelin's Avatar
z71_fourwheelin
Probably nicked a few wires when using the cable fish. Id pull the tank and start searching there.
Old Mar 14, 2013 | 09:08 PM
outlawDFFD's Avatar
outlawDFFD
Stage II
thanks for the info. i will start there.
Old May 4, 2013 | 03:27 PM
Dew Me's Avatar
Dew Me
What ended up being the problem? I just removed my gas gauge completely in favor of tweeters figuring I'd use the range as my gas gauge. Now I have the dashes showing up. I know I didn't nick any wires b/c I did remove the tank to run my amp power wire. I'm about to re-install gauge and hide it inside the fairing hoping it has to do with completing a circuit. But you are still using the gauge right?
JonGolden
Jun 2, 2014 11:20 PM
GarboHD
Jan 3, 2009 08:18 PM
Shoe
Jun 8, 2008 11:36 AM
Geoc
Sep 12, 2006 03:29 PM
