I'm stumped!
Old Mar 17, 2013 | 06:08 AM
trnewman's Avatar
trnewman
Originally Posted by Tinman265
Just a little more info here.....
Did you use the custom passing lamp bracket? Did you move your existing led replacement bulbs from the stock bullet turn signal housing to the new bullet turn signal housing on the passing lamp bracket?
Yes I used the same LED bulbs in the new turn signal housings. I bought new housings because I went to the gloss black bracket and my bike had chrome tuns before. Otherwise I could have just used my existing turn signals with the kit.
Old Mar 17, 2013 | 08:47 AM
Nitro NHRA's Avatar
Nitro NHRA
Originally Posted by trnewman
No short...the ground is working. The light goes out when I disconnect the ground wire.
Wiring schematic shows that the ground wire goes to a chassis ground not tied back into signal ground. Am currently installing my P7 led's all three holes. the ground wire for my Aux light is grounded to the light bucket. Does your ride have a switch for the spots or are they tying into the ACC switch. Figure a ground is a ground but worth a try. or maybe has something to do with the switch.
Old Mar 17, 2013 | 08:56 AM
trnewman's Avatar
trnewman
Kit came with the spot light switch which is wired into the harness under the fairing cap. That was pretty straight forward with good directions.
Old Mar 17, 2013 | 09:40 AM
Tinman265's Avatar
Tinman265
Well seeing that the only thing that has really changed is the housing that you put the bulb in I would say you have some kind of problem with your load equalizer. The fact you put a standard bulb in and the problem goes away pretty much say it all. I would suggest checking all your connections and pins at the load equalizer and if there is nothing wrong there give Biketronics a call. The problem lies somewhere with the load equalizer.
Old Mar 17, 2013 | 10:32 AM
1st 96 ultra's Avatar
1st 96 ultra
what he said , you but a bulb back in and it compinsated for the bad or not working equalizer and things worked ok , check the equalizer or replace it
Old Mar 17, 2013 | 10:43 AM
trnewman's Avatar
trnewman
I guess I'll try a new load equalizer....thanks
fporfido3
Apr 10, 2019 04:24 PM
Superfly3176
Oct 31, 2014 09:02 AM
gnewman
Jul 14, 2013 10:31 AM
Larry Jeffords
May 12, 2013 06:22 PM
trnewman
Mar 16, 2013 07:02 PM
