Plate relocated on RKC
Old Mar 18, 2013 | 11:53 AM
BamaBoyjc's Avatar
BamaBoyjc
Originally Posted by smokindave
Also, HD offers a plate mount that has a radius to match the fender, mounting is easy.
Which plate frame is that? I've been looking at the HD one that has the radius but was told it is for SG and won't fit a 12 RK. Thinking of buying it and trying it out. Any info you have is appreciated
Old Mar 18, 2013 | 12:42 PM
TI06's Avatar
TI06
Originally Posted by Neckball
No need for the OP to have to splice anything. His bike is a RK Classic which does not have the fender tip light. So inside the tail light housing there is an empty spade terminal. All he has to do is plug into that. I did the same thing.
I see the open spot in my service manual. It's just above the tail lamp multilock connector. Can I just get a connector for the 2 wires from a dealer? Just plug and play?
Old Mar 18, 2013 | 12:46 PM
Keithhu's Avatar
Keithhu
Do you see the solid blue wire right next to the plastic sheathing leading into the connector? You have to splice one of the wires from the plate bracket in to that lead, the other is ground. Call Radiantz, they will tell you which wire from the plate is hot.
Old Mar 18, 2013 | 12:50 PM
Keithhu's Avatar
Keithhu
Look at the pic below.
I cut the plastic sheathing (with the numbers on it) along the length of the wire bundle. Peel it back, you will put it back on the bundle. Splice and solder the hot wire from the plate into that blue wire (put shrink tubing on before of course).
Then replace the plastic sheathing and wrap it in electrical tape.
Old Mar 18, 2013 | 01:13 PM
TI06's Avatar
TI06
Thanks Keith!
Old Mar 22, 2013 | 07:39 PM
Gotham's Avatar
Gotham
I did mine changing 2009 Road King type, Plug and play on my 2006 RKC.
Ed
Old Mar 22, 2013 | 11:30 PM
TI06's Avatar
TI06
Looks good Slider, I like it. It's too bad RKC's didn't come stock this way.
Ldp1959
Jun 19, 2015 11:25 AM
LeadSSled
Aug 25, 2013 05:57 PM
C908
Jul 19, 2012 11:21 PM
DeluxeW00kie
Jan 7, 2011 06:37 PM
Sooee
May 14, 2006 12:32 AM
