brake line change
Old Mar 20, 2013 | 11:28 AM
pureoper's Avatar
pureoper
Default brake line change
I have a 2010 road king ,non antilock,im putting apes on so ill be changing to longer brake lines.Whats the best way to get the brake fluid out.I have a mightyvac should i pump it out with that?Give me some suggestions,I will get it done just want to do it the best and cleanest way.Thanks for any help.
Old Mar 20, 2013 | 12:28 PM
grbrown's Avatar
grbrown
If you have one that will be quick. Whenever brake fluid is involved disaster is looking over your shoulder, so take care and precautions!
Old Mar 20, 2013 | 12:59 PM
B@man's Avatar
B@man
put a hose on the bleeders and put the other side into a cup, crack the bleeders and go to lunch
Old Mar 20, 2013 | 02:59 PM
HTNHARD's Avatar
HTNHARD
Put towel on tank. Undo brake resivoir. Hook Mighty Vac cup and tube up to brake bleeder. Pump up Mighty Vac and crack bleeder. Keep resivoir full, and the Might Vac pumped until you see clear bubbless fluid going into the cup. Close up shop and see how it works. Good luck
Old Mar 20, 2013 | 04:13 PM
uuscotty's Avatar
uuscotty
and use something like large plastic trash bags over your towels to cover your paint in case you have a large spill to keep it from soaking through the towel. Brake fluid is very bad on paint. Maybe it's being overcautious, but I always like to be extra careful with brake fluid...especially with something that only takes a few seconds and is reusable in the trash can later.
Old Mar 20, 2013 | 05:21 PM
Boyer8's Avatar
Boyer8
Speedbleeders!! I replaced my lines due to APE install and took less the 10 mins to do. The make life so much easier. I have ABS and have not had any issues with the module. But I never turned the key on either until after the lines were replaced and the lines bled.
Old Mar 20, 2013 | 07:47 PM
FLHTCU Owner's Avatar
FLHTCU Owner
Don't have the mighty vac but used a similar brake bleeder and it worked like a charm. Replaced mine with Goodrich brake lines.
Mohammed Alyahya
Apr 11, 2019 03:21 PM
slyder
Dec 23, 2010 09:59 PM
neverdown
Wheels/Tires
Jun 5, 2009 09:57 PM
blackedout08
Sep 10, 2008 12:48 PM
devils haircut
May 18, 2008 08:40 PM
