whats this tube for ?
Old Mar 25, 2013 | 07:08 PM
Houston_t's Avatar
Houston_t
Default whats this tube for ?
Had a random oil leak and i believe it may have been coming from this hose, cleaned the area but now its not leaking anymore so im not sure if this is the problem or not.
Old Mar 25, 2013 | 07:11 PM
Frankenbagger's Avatar
Frankenbagger
Transmission vent line. I'd double check your trans fluid level and if its good, I wouldn't worry.
Old Mar 25, 2013 | 07:15 PM
Houston_t's Avatar
Houston_t
just had all the fluids serviced back in january, have not ridden it yet just start it up every now and then. leaked out an oil spot about the size of a diner plate is this normal ? new to harleys this is my first one, but never noticed any leaks before the other day.
Old Mar 25, 2013 | 07:36 PM
hockey8787's Avatar
hockey8787
whoever did the oil change may have put to much back in, i would check it as said above
Old Mar 25, 2013 | 07:38 PM
Houston_t's Avatar
Houston_t
ok thanks for the help, will check tomorrow.
Old Mar 25, 2013 | 08:35 PM
CndUltra95's Avatar
CndUltra95
When you go to check the oil level make sure the bike is upright and the **** is resting on the threads when inserted into the transmission fill hole.
Hope that makes sense ...as you said your new to Harley...
Rob
Old Mar 26, 2013 | 01:50 PM
Lowcountry Joe's Avatar
Lowcountry Joe
That oil under your bike may be the dribble they spilled all over your front end when they removed the old oil filter.
Old Mar 26, 2013 | 02:50 PM
Frankenbagger
Size of a dinner plate is fairly large. If its been sitting for a couple months and just puked out that much oil when you started it up, you can probably rule out leftover spill from the oil change. Sounds to me like an over-fill.
It happens... Buddy of mine had his bike at HD for fluids, there was a miss-communication between two techs. The guy finishing the bike and filling the fluids thought the trans was dry, and double filled it. Bike puked oil all over the parking lot out of that vent line.
Old Mar 26, 2013 | 03:26 PM
TUCCI's Avatar
TUCCI
Miss-communication or not that kinda crap is why no one ever touches my bikes.
Old Mar 26, 2013 | 03:30 PM
Frankenbagger
